Jet with Reeves-type drive problem thread?
Rich Pearson in Mill Creek, WA
>I seem to recall a thread discussing "stuck" Jet lathes with Reeves-type drive pulleys. My searches have not found it.
Any help out there with either a "fix" or a link to the threaad?
thanks
Re: Jet with Reeves-type drive problem thread?
>I've never owned the jet but have had other lathes with Reeves drives. I find that periodically you need to clean and re lubricate the bar that the pulleys slide on. It gets kunked up and the spring won't push the pulleys apart and the crank gets, well cranky. A good cleaning has always solved the problem for me
Dennis Taylor
>I happen to have had the problem first hand...from the recommendations of Jet Tech support, I was told to clean the drives with brake cleaner, in the spray can, spray the pulley's and then move them with the lathe running and continue to spray to clean, after that, spray with a lube....silicon spray....that should resolve the problem....sounded pretty common, and they say it is junk build up...also it cleans the cosmoline from the spindles & shafts from shipment, that is what really had mine junked up....hope this helped...Dennis
Thank You
>Thank you. I will try the brake cleaner. I am also glad this is a known problem!
