PMLA, Jet or Delta Midi?
mark4583
>Im looking to get a smaller lathe just for small turnings, Mostly Pens.
Penn State has a PMLA Pen making lathe, will this limit me to Just Pens or would I be able to do other small turnings?
How does the Jet VS and Delta Midi compare amoung the three lathes>
I have a Larger Jet Lathe that I use for larger turning but Im wanting somthing I can set up in the back room and just do small stuff like Pens and so forth.
Whats your oppinions on these?
Any other advice is appricieated.
Thanks
Re: PMLA, Jet or Delta Midi?
RevDoug
>Stay away from the PMLA and go withthe Jet. The PMLA does indeed limit you to pens and not so well at that. The Jet will allow for small bowls etc. You'll be so much happier.
Turn 'em round,
Blake Washburn
>I love my Jet mini. I've done some small bowls on lathes and just finished a peppermill. I'd go with a Jet only because that is the only lathe I've been on :)
Blake Washburn
>Mark I think the jet non variable speed is one of the best mini lathes out there. The Vicmarc probably gives it a good run for it's money.
Sam Scalzo
>Mark,
I have a Jet Mini with a var.Speed and I love it. Have turned lots of pens and small bowls. Works very well for me. I have also used the Delta and it worked well too. Gave it to my grandsons.
