Finish on Cedar
Finish on Cedar
Bob Moffett
Finish on Cedar
Bob Moffett
>I just finished a 12" bowl out of cedar. What is a good finish to use on Cedar? Is there any special prep work necessary, other than sanding or course, prior to putting the finish on cedar? It is probably 50% sapwood and 50% heartwood.
Re: Finish on Cedar
Re: Finish on Cedar
RevDoug
>I like several coats of Danish Oil. 7 - 10 coats rubbed out with steel wool once each coat drys makes for a fine finish that is in the wood not on the surface.
Turn 'em round,
Re: Finish on Cedar
Re: Finish on Cedar
GaryG in MD
>Bob, I have seen a lot of answers to this question in the past on WC. I recall things about clear finishes, smell, etc. Do a search in the Turning Archive, and I'm sure you will find a lot of good advice. ...Gary
Re: Finish on Cedar
Re: Finish on Cedar
Jake Niedling
>I have used Danish oil on some cedar christmas ornaments. It will take many coats. The end grain will suck-up the oil, but just keep applying and wipe off the excess each time. It will take some time to let each coat dry before the next one.
I am sure multiple coats of any of your favorite finish will work.
Re: Finish on Cedar
Re: Finish on Cedar
Steve in NC
>I have used Shellawax Creame on Cedar with good results
Re: Finish on Cedar
Re: Finish on Cedar
David Breth
>Somebody posted a message a few months ago - maybe even over the summer with a gorgeous cedar bowl they had turned. That person finished with Beeswax, but it was cut with something I no longer remember. I recently turned one and used beeswax by itself. Quite pleased with the finish. Buttery soft too.
David B.
Re: Finish on Cedar
Re: Finish on Cedar *LINK*
JKJ in East TN
>Below is a recent thread concerning cedar. I remember another last spring or summer I think.
thread on finishing cedar
Re: Finish on Cedar
Re: Finish on Cedar
Allen Neighbors
>If you're not simply interested in retaining the smell of the cedar, try this: (I adapted it from a posting by Carole Valentine.)
I mix about 40% lacquer and 60% lacquer thinner. Turn the lathe on slow. Apply the mixture with a soft cloth (ladie's shoulder pad works really well), followed immediately with a clean, dry, lintless, cloth. Buff 'til dry. Let set for a while to thoroughly dry. Apply beeswax. Melt it in by buffing. It's a gorgeous, soft finish.
Thanks, Carole V. I've learned a ton from you and others on this forum.
Allen, praying for rain in Childress, Texas
