Question for drum sander owners
Colin Spencer
>I am in the procees of building a drum sander based partially on plans found on the web. In these plans there is no recommendation as to the motor / drum RPM. Can one of you who has one of these please tell me the ideal rpm of either the drum or the motor?
TIA
Colin
Re: Question for drum sander owners
ben d.
>I built a 24" drum sander with a 4 1/2 dia. drum including the sandpaper on it. I run it at 1725 rpm and seems sufficient to me. I used the motor that I had and it is a 3/4 hp. but should be at least 1 1/2. Although it does a good job it is slow. Of course if you are not doing production it really dosen't matter I guess. On the drum I used velcro and velcro backed sand paper so grits can be changed fairly easy.
Hope this helps or e-mail me if you like.
>I have a Performax and it has a 1HP 1725 RPM motor and it's on a 16" drum, wide that is. The motor could be more powerful. 1 1/2 or 2 HP maybe. It's slow, but its a sander, not a planer. It will do a beautiful job on burl or curly woods my planer would turn into garbage.
