Does anyone have one of those sunlight lamps?
Carole Valentine
>Are they really the equivalent to bright sunlight? I sure would like to have some bright sunlight shining on my lathe.
Re: Does anyone have one of those sunlight lamps?
I had bought one but returned it.
Jim K in Trappe PA
>It didn't seem any different than flourescent.
Jim
Walter Ahlgrim
>The wife has them by the loom, they work well there, lots of light, good color of light, not a lot of heat. The first bulb lasted about 100-500 hours not the 5000 hours in the advertisement. When asked about the short life and there reply was the �starting the lamp shorten its life�. The bulbs are about $50.00 with shipping for the large lamp. In my lamp the bulb is not covered and is very fragile. Even on cloudy days the sun light is brighter than the lamp from 9am to 3pm. I like a 50 watt 12 volt halogen spot on the ceiling behind the tail stock as my main light.
Phil Joines
>I understand that the 5000 degree kelvin lamps for flourscent lamps are very close to sunlight. We use them as plant lights. They are available at the HD here.
>They are near the same color as sunlight and you can use daylight film to photograph under them but I don't know if they emit as much UV as grow lights. They might I just haven't read it in thier literature. They are much less expensive than the supposed "sunlight" lamps
Carol Reed, the Router Lady, Dubuque
>I have two over the four monitor arrangement on my desk. Great reading lamps. They flood the whole work surface with no glare on the keyboard or paper and books. I found them for $30 each at Big Lots!
The lathe, on the other hand, is 1700 miles away in storage. Sniff. Come-on, summer! Tools will see daylight and sawdust will be made!
