Tormek Sharpening-Anybody use it?
Greg Haugen
>I have talked with Nick Cook. He swears by the Tormek sharpening system. Woodcraft has a sale Sat. 10% off EVERYTHING. Any feedback on them?
Thank
Greg
Re: Tormek Sharpening-Anybody use it?
Mike Cunningham (Cape May)
>I'd be lost without it. I've had mine for two years and have most of the jigs, there's not much that I can't sharpen.
There are those that say it's not fast enough. In response to that I'll say two things. First, when I need to remove a lot of metal to reform an edge I use my regular old grinder, then move to the Tormek to finish it.
Second, how fast do you need to be? I can hone a bowl gouge in seconds, certainly no more than two minutes and that includes placing the tool in the jig and the actual shapening.
Like many things in life, It ain't cheap but it sure is nice!
Darryl Hansen
>Yes it might be slow if your are resahping your tools. However, since I am one of the dummies who can not sharpen a gouge that will cut anything tougher than melted butter without considerable help on a grnder the Tormek has been a life saver. I can sharpen a gouge in about 30 seconds on the Tormek on a grinder well . . . about the same length of time but it won't cut anythig when I am done. The Tormek was worth every penny to me at least...
Darryl Hansen
>you might check with www.sharptools.com to be certain the 10% off isn't aobut the same as Ferris sells it all the time..
James McClure
>It's a great system. I've had mine for a couple of years and am almost to the point of needing to replace the stone. The edge you get from it is terrific. It's really great for bench chisels and carving tools, but some say it's overkill for turning tools. I think it's all in what you get used to using. I like the edge I get from it, but I think the edge you get from a bench grinder with a 120 grit wheel is not far off either. It is slower to use than a bench grinder. Not too much slower if you are just touching up the tool, but unbearable if you are completely reshaping a tool. Before I had access to a bench grinder I spent over an hour reshaping a bowl gouge. If you are only using it for turning tools, then I don't think the extra money is worth spending compared to a bench grinder and a jig system like the wolverine. If you will be sharpening other tools that need a more refined/polished edge like carving tools, bench chisels, scissors, kitchen knifes, ... then go for it.
Gary Ratajczak
>See my post down below "New Wet Sharpener". Looks like Tormek, but lower price. Seems to me it would allow you to buy a few more jigs. I don't own either, but am looking.
Re: Tormek Sharpening-Anybody use it? *LINK*
Ed Moore
>Daryl,
I think you left part of the URL off when you posted it. Yours referred to an industrial site that probably doesn't carry the Tormek.
Consider: http://www.sharptoolsusa.com/
or
Sharptoolusa
Jeff in Topsfield, Ma
>I have a very complete Tormek system, I purchased it about the same time I started turning 4 years ago. The reason I purchased it was primarily for its ability to sharpen planer and joiner knives, I was going through those at a good clip at that time.
I used the Tormek exclusively until about 6 months ago when I bought a 3/4 inch bowl gouge. I started to shape the gouge and in a short period of time said enough is enough and purchased a grinder and wolverine setup from Woodcraft. I use the grinder for all of the shaping and much of the sharpening, but I also use the Tormek for a lot of sharpening. For me it's just a matter of which one is setup for the tool that I am using.
It's a nice luxury to have both tools setup near the lathe. I can leave the wolverine setup for the big gouge and the scraper, and the Tormek for a small gouge. An do all of my honing on the Tormek.
The edge I get from the Tormek is a little bit better than the edge I get from the 120 grit wheel and power honing. But it's not enough of a difference that I would pick one over the other based on just turning. If you want to sharpen other items then the Tormek would probably have an advantage.
I do find the Tormek takes a lot less steel off than the grinder. I also find that it is easier to reset the Tormek to exactly the right setup to resharpen a Tool, much less error than the grinder. These two observations may be related.
The tools to true and regrade the Tormek wheel are usually included with the basic package and they do a nice job.
I find that the Tormek doesn't do as nice of a job raising a burr on a scraper as does the grinder or the veritas scraper burnisher.
The Tormek does a really nice job on those little scraper bits that fit in the Sorby hollower and similar tools.
Let me know if you have any other questions, happy to answer if I can.
- Jeff
Richard Allen
Re: Tormek - avoid for turning tools!!
Richard Allen
>Please note that the following is what I found out from my observations. Others doing the same sort of testing may very well arrive at a different result.
Tormek vs half speed bench grinder. The bench ginder is a far supior tool for sharpening turning tools.
About 4 months ago I switched to a Tormek for sharpening my turning tools. It was clear to me in the first week that the time required to sharpen with the Tormek was at least three times as long as with a half speed bench ginder.
I was curious to find out if the edge I could get off the Tormek was better for woodturning than the edge from a half speed grinder. For four months I used nothing but the Tormek to sharpen my turning tools. I became familure with the quality of the edge produced onto my bowl gouges. I did the honeing and everything I even inspected the edge under magnification to be sure I was achieving a consitantly sharp edge. At first I thought the edge off the Tormek was worse than the edge off the half speed bench grinder. Of course it could have been the wood I was turning was more abrasive then other wood. Well a month ago Iswitched back to the half speed bench grinder to complete my testing.
The edge off the half speed grinder cuts better and the edge last longer thean the edge off the Tormek.
The half speed grinder is at least three times as fast at renewing the edge on a "half inch" bowl gouge.
The maintance of the Tormek is at least 10 times more involved than the maintance of a half speed bench grinder. The Tormeck needs water, honeing grease. There is a LOT of cleaning involved. Dressing the wheel of the Tormek takes a lot of time and ends with a LOT more cleanup.
The Tormek does a terrific job on other tools knives and sissors.
There is one tool that benifits from the use of the Tormek. THe Skew, when sharpened on the Tormek is easier to use and cut more cleanly.
JKJ in East TN
>I use a Tormek, a half-speed grinder, and a full-speed grinder. For me, the Tormek is far better for most turning tools. Do a search hear for many past discussions. You'll find some people opposed to the Tormek, some because of value, some for speed, and some for edge. I got the impression that a few tried and gave up on the Tormek without learning how to use it properly. For me, it gives an astounding, razer-sharp edge every time. I really like the repeatability of the jigs for fingernail grinds - if set up properly, it takes only a few seconds to put on a perfect edge by taking off VERY little metal. The variety of jigs adds versitility as well - I sharpen sissors, knives, etc. I have not yet tried planer and jointer blades, but I will soon. It is expensive, but if you have the money, I'd say go for it.
Rick Davenport
>I use my Tormek every day in my mobile sharpening business. I sharpen 10 to 50 blades a day with it and get consistent results that picky chefs really appreciate.
It also does a superior job on my turning tools, but the process wears down the stone very quickly.
I've already replaced my Tormek stone once (after 6 months) and I want to save that smooth surface for knives.
So I use a wolverine/slow grinder set up for turning tools now.
I believe I have to sharpen more often with the wolverine, but not much.
I can't say enough about my Tormek, but I would hesitate to buy a knockoff until I knew more about it.
I believe Jeff Farris at Sharptools knows more about the knockoff.
Rick Davenport
"Life shouldn't be dull."
Steven Antonucci
Love mine-
steve antonucci
>It's the only tool in my shop that I can't "upgrade". Someone here has proven under high power microscope that the Tormek edge IS BETTER than other wheel type. Add to it the fact that there are no hot sparks, no blued edges, and frighteningly scary tools- and you understand why it's the premiere tool of it's type.
If I need to reshape or grind, I use my beltsander in a bench vise.
Steve
Tormek rules!
Fred Bearman
>I bought mine from Jeff Farris at Sharptoolsusa (actally at a woodworking show) and they double the standard warranty to 6 years - not to mention the fact thay he and his wife are very nice people. I was wavering on purchasing this or the Wolverine system (sorry, I could only go with one or the other), then my wife found out what it could do for her knives and scissors, and that ended the discussion. Am very happy with the Tormek, but for me at least, there is a learning curve (but I'll get there).
Fred Bearman
Port Huron, Michigan
Peter Charles Fagg (UK)
>Just for the record, I agree with Mike, I would be lost without my Tormek. Yes it is the smaller version but it still returns a great edge to my gouges after the initial bench grinder (new tools) or at the end of the day regrinding all the tools ready for tomorrow.
I would recommend the system to all comers.
Regards Peter.
