Re: need source for vacuum line filter
Dinyar Chavda
>Dick:
I made my own filter, using the approach shown in Bill Noble's article on vacuum chucking. Basically, he recommends using some large diameter galvanized pipe (for example, 2 inch) filled with cotton wool or wadded up filter medium or even a rag. Put a cap on each end and drill and tap the cap for � inch pipe (or use a
reducing fitting. I used the filter medium (it's what's used to put on heat registers in your house), and used a reducing fitting. Put one on the line leading to the chuck, and also one on the output line, which, in addition to acting as a filter, also acts as a muffler.
Seems to work. Periodically, you can open it up and see if it needs changing.
