non battery powered dust masks - "resp-o-rator"
John U - Charlotte, NC
>I have the Resp-o-rator, and am "ok" with it.
* Can wear with glasses, safety glasses, face shield, hearing protection, etc.
* The mouthpiece, used similar to a scuba mouthpiece, didn't take much time for me to get used to.
* The mouthpiece, back tubes, and back-mounted filters are all easy to take apart and clean.
* The tethered nose clip I still have troubles with - just can't seem to find the right pressure that I'm comfortable with. Just personal preference though.
* When you first start using it, you may slobber all over yourself. Saliva does build up, and with your mouth clamped around the mouthpiece, you tend to swallow differently. If you slobber, it will end up covering the front of your shirt/smock/apron - cover that with sanding dust, and you have a nice paste stuck to the front of you. You should overcome this problem though, and stop slobbering on yourself. My first impression was really low because of this.
* The neck tubes leading to the back-mount filters are flexible, but if you have a large neck, they will give constant pressure on the sides of your neck where they bend around it. I feel it most when I'm turning my head to see who came in the garage when I'm working.
* Spare filters are easy to get, at least in a city - Klingspor's and Woodcraft in Charlotte both carry them. I see them in the woodturning catalogs.
* Filters do seem to work - dust collects on them, and I'm not seeing the dust when I blow my nose, etc.
Overall opinion - neutral. It may be better suited for some people, but not others.
Would I buy it again if I had to? Likely not. I work in the environmental field, and am properly fitted and trained on wearing full and half face respirators - either one of these would be my choice for my next purchase of a non-powered device.
