Norfolk Island Pine Bowl/Vase
Charlie Anderson
>This is the NIF that I had asked for design advise a week or two ago.
Charlie Anderson
Re: Norfolk Island Pine Bowl/Vase
Charlie Anderson
>You may have noticed a few dings in that previous picture. Here's what it looks like from a different angle. I think I spent around 12 hours on this thing!
I couldn't get my vacuum chuck to work so I was going to finish the bottom down to a nubbin then cut it off. What I forgot was that I had the live center in the tailstock over the pith. When my gouge hit the pith, the bowl went flying.
If I can figure out how to get it back on the lathe, I can cut it down and make it a bowl. I think there's enough wood left to use the expansion jaws on my chuck. Any suggestions?
I hate it when that happens.
Dave Smith, Longview, WA
Brad Vietje
>Bummer, Charlie !
You can drive this with a friction chuck, and turn it between centers.
If you have a non-pointed live center*, you can carefully re-center the foot on some tip that won't split or mar the bottom of the bowl, and drive it with a home-made friction chuck. Some people use a small diameter friction chuck that just pushes on the bottom inside surface, but I'd recommend turning a piece of scrap that will support the thin walls, and fit the bottom as widely as possible. You might also be able to use a thick friction chuck , turned from a 2 x 8, for example, that will hold and support the widest part you can reach from the opening. The best thing would be to do both -- make a chuck that has a long part that will extend all the way down to the bottom of the bowl, and a wide rim to gently support (but not crack) the wider profile. You should then be able to carefully turn through the solid parts that remain to make a nice little bowl, with the rim well supported by your carefully-sized friction chuck.
If the remaining wood is strong enough, you could then use a jam chuck to drive the rim, and finish off the foot, or even jumbo or Cole jaws, or press on and carefully work on the foot area between centers.
* if you only have a pointed cone center, first turn a little conical shape to fit over it, which you can make to fit the foot exactly, or you can place soft rubber between the foot of the bowl and this little adapter.
Safe Spinning,
Brad Vietje
Newbury, VT
Glue Block
Bernie
