We value your privacy.
>Rick The only one that comes close in my opinion is the Vicmarc 300 which is a great lathe. I haven't looked at prices in a while but believe the Vicmarc was a little higher. Great really solid machine however. The other lathe to look at in that price range is the Vega 2400. It's not as fully capable as the Powermatic but is a really good bowl lathe if that's what you need it for.
I did a fiar amount of research before pulling the trigger on the 3520B, turned on one, etc. For what you get for the money, It seems to be a great lathe and a great value.
The other lethe in this price range is the Vega 2600, which I think is more of a dedicated bowl lathe. I have never turned one, but I have heard realy good things about it.
FWIW, I paid $2550 w/free delivery from toolnut.com. It due here in about 5 days.
>For the price I'd say go for it. I almost did a couple years back but ended up with the Vicmarc VL300. Not even close in price (about $4500). The VL200 is in the same price range. Would I do it over again? Nope (long story, lots of problems with lathe and distributor). Doing it over again I would have gotten the Powermatic and saved myself alot of grief and a bunch of trouble and cash. Just my $.02, good luck man, Guy
If you can get one at that price, go for it. There was a promotional deal that ended yesterday, but check with Tool Nut or other sources -- the price may be a little higher by now.
I only turned on this lathe (3520-A) for about 30 minutes a few years ago, but it had the quality, capacity and mass I was after, and I like the sliding headstock (vs. rotating) for conversion to a short-bed bowl lathe. I have begun getting sore hips and some back pains that are made worse by leaning over the lathe bed, so the ability to stand in front of my work, especially for hollow forms, was important. I was very tempted by the Nova 3000 DVR, and had originally planned a DVR as a spindle lathe, plus a Vega 2600 as a dedicated bowl lathe. I decided on the 3520 because it will fill both bills quite nicely, and leave me quite a few more bills to invest in the solar retro-fit of my house. It might not be the perfect lathe for everyone, but I think its the best one for me right now.
>I looked at Vega and Vicmarc but they didn't seem to provide the flexibity of the Powermatic.
So I just ordered one!
$2650 plus $40 liftgate delivery charge plus WA state tax (ouch! but then we don't have an income tax).
And then a cover for the trailer so I can move it out of the carport so I can move my van out of the garage so I can expand my shop to fit the new lathe and the new dust collector and, and, and.......
>HI Rick, yes, it's one inch. I like the new Powermatic "B" model, a couple of new features....it has a rudimentary index mechanism, which is an essential feature for someone like myself. The speed control monitor is now up front, which is also better. The top of the headstock is now adorned with a rubber mat, if nothing else it gives a nice appearance.
It's nice to see the quality of the Powermatic seems to be continually improving....I say go for it!
>Rick, just go ahead and pull then trigger. You will not be disappointed with the 3520B. I have been using mine since December and I am very satisfied with it for bowl and vessel turnings. I enclosed a picture showing my 3520B lathe with a 14" dia Apple bowl on it. I built 6" high Maple legs under the lathe to get the center line higher. I am 6'3" tall and I wanted the center line be a comfortable 2" above my elbow. Have fun with it! This is the same advice I gave to LT.
The remote is an extra and I would recommend it if you are planning to do vessel turnings. One of the best features of this lathe is that the headstock can be moved to the center of the bed for vessel turnings. You can remove the tailstock and stand at the end of the lathe for hollowing vessels. In this position it is real convenient and safe to have the remote switch. Otherwise you would need to reach around the spinning vessel if you run into trouble. The remote has a magnet on the back so you can position it anywhere on the bed you want.
If you need new faceplates I would recommend buying the powermatic ones. The powermatic ones have large wrench flats and sets screws for reverse turning. You get a 3" faceplate with the lathe.
Now since you asked, there is a new lathe on the market from Grizzly it is called the GO456. It has a 20" swing, 2hp variable speed motor and weights in at 633 lbs and sells for $1495.00. I own the Grizzly G1495 and I was not happy with it for bowl turnings larger than 8" diameter. It was fine for pen and small bowl turnings. The G0456 looks to be more robust then the old G1495 but I would still recommend buying the Powermatic 3520B. As far as I am concerned a new lathe should be the most expensive tool in your shop since you clock more hours using it then any other tool in the shop.
Congrats on the new lathe purchase. I have had an "A" for almost a year and I am really pleased with it. The toolpost diameter is 1" as Keith mentioned but you need to be careful when buying aftermaket toolrests for the 3520a or b because they need a longer tool post.
When ordering the toolrest be specific and ask if the post is long enough for the 3520b. I had the Sorby toolrest system (bought from Lee Valley)for my old Delta and the posts were too short for the 3520. (But I found the right posts at Cutting Edge Tools)
I remember when you were waiting on your lathe; I was selling Vicmarcs at that time also. The problem most likely was beyond the control of your distributor. Vicmarc just will not support their dealers. Their crating is terrible and damages occur in shipment routinely. It takes 2 things to make a lathe a good buy: a good machine and good support; with Vicmarc there is no good support. It is really too bad. I have a VL300 also and it is a very good lathe over-all. There are a few details that need attention but the company prefers to sweep these under the mat rather than fixing them. A comment to Victor about these problems draws daggers.
>Sorry to hear you no longer sell the Vicmarcs, Terry. I was hoping to find a dealer on the East coast but there are none now. I accepted delivery of a VL300 shortbed from Craft Supplies yesterday. It's the bench-mount model & shipping, crating and condition were all perfect (see picture below). I'm pretty confident that they will give good support based on my experience so far. Roger Durst was a lot of help with my questions before purchase.
>Thanks! It's going to take a little getting used to. Been using a VL100 for the last 2.5 years. They certainly look like Mutt and Jeff! Got it running today & just let it go for a half hour to make sure the bearings are loaded correctly. So far so good.
