WE MOVED...
airbrush advice please
ken chase
>I want to paint my woodturning/carving project. I have experience with an airbrush but never painted wood. Would the airbrush paints offered in the Treeline catalog be a good choice? They are called Polytranspar airbrush paints. Imput will be greatly appreciated.
Re: airbrush advice please
Jim Shaver - Oakville, Ontario
>Hi Ken,
I do not know those paints.
I used to do a fair bit of model building up until woodworking became my obsession. I used two air brushes quite a bit, both a single and a double action Badger. When it came to paints the acrylic paints were my favorites. They applied them selves well and were easy to clean up after.
I used to use paints made by Tamiya, they had a wide colour pallet, not sure if they do so now.
Not sure if that helps or not....just my 2 cents..
Take care,
Jim
Re:thanks Jim
ken chase
Mike Schwing from Md.
>Ken I have used them. I find them to require reducing before use, as they are thicker than I prefer. I like to lay down multiple layers of paint to build color rather than apply it all at once, and this requires highly reduced (thinned) paint. If you are using a tip that is smaller than .5mm I bet you have trouble with them unless highly reduced.
My preferred source of paint is Golden airbrush colors, reduced with their medium when needed. Their transparents are wonderful. Createx will do in a pinch but I find they require a good bit of reducer, too.
I'm also learning how to paint realistic flames and am using House of Kolor paints for that. They're SWEET!
Mike are you going...
Paul in Phoenix, AZ
>...to paint flames on your Ironman bike? ;)
close!
>I'm going to paint my carbon fiber racing wheels in flames radiating out from the center on the rear disc and around the radius on the front. Might have to do my helmet, too..
I'm learning technique from the guy who did this plane...
oops
>Should have said "learning the techniques OF the guy who did this plane." not "OF". Mike Lavallee of killerpaint.com
ken chase
>Mike: Thanks....great stuff. Have you used inks? I have been playing with them. Also. When you use the paints you suggested is some kind of primer necessary first?
>Depends on what your goals are Ken. Do you want the wood to show through like this? ... ? If so, then the only primer needed is a sealer of some sort, unless you want the paints to absorb into the different grains at different rates. If water based paint, use a non water soluble sealer, and vice versa. Or do you want to obscure the grain, as I did to this featureless basswood..
If so, then this was painted with a white gesso, but any sandable primer would have done fine. Water based acrylic airbrush paint should generally be sprayed so it almost dries as it touches the work (except for certain special effects), this makes it very easy to work with on most surfaces. It is not generally laid down so thick that the work appears "wet". The eyepod pictured was gesso'd, then painted with several oranges, yellows, and browns, and finally highlighted with yellow. There are probably 30 coats of paint on the exterior. Wish I still had that sucker.
Very cool!!!
Paul Porter in Phoenix
ken chase
>Great photo. Thanks. I neglected to say I would be coloring wood. On my present project I want to create a faux finish with wavy grain patterns and spalting. Yesterday I blocked the whole piece out with colored india ink using a brush. I have had some success with artist acrylic also with a brush but I think airbrushing could yield a better result if done well. Your piece looks like it was sprayed with a translucent red. Am I correct? Again........thanks
