Tried it today!
Ron McKinley
>I put the Apprentice Chuck through the paces today. I tried every set of jaws and all of them worked perfectly. I had some pieces I had turned earlier and either didn't like or in one case the flange broke off a redwood twig pot.
I started with the twig pot (about 6" high) and chucked it in the flat or Cole jaws and it held it fine while I turned the broken flange away.
Then a 5" bowl of tiger-stripe eucalyptus that I didn't like the base so put that in the flat jaws/Cole jaws and made the base look a lot better. The flat jaws/Cole jaws are optional and don't come with the set. They work fine but wish they were a little bigger so I could use the full capacity of the Jet 10" Midi lathe. It will clamp about 5 1/8" in compression mode.
Then I switched to a redwood goblet I had turned and screwed up months ago and using the #1 jaws held it in the expansion mode and re-turned it. Now I like it. Then to a coaster blank. I had made my wife some candle bases for Christmas presents out of cherry and had one left over so I chucked one in the pin jaws in the expansion mode and now she has another one!
There was one thing about the chuck that concerned me. It doesn't have a back on the headstock end. It's open and you can see the gearing inside. I called Craft Supplies to see if I was missing a part and they said, no, that's the way they're made. He also said the Axminster Chucks are made the same way. He said just blow it out occasionally.
After turning all day there was very little dust/chips inside and it blew out with no problem. All in all, I like this chuck, especially all the different jaws that come with it. I do a lot of small work so the small jaws come in really handy.
The fit and finish is as good or better as my Nova Midi or any other chuck I've seen. Just one other little nit: it only comes with 8 screws for the jaws and I'm always dropping screws, etc. into the sawdust never to be seen again. My Nova Midi came with a few extra screws.........Ron
"A Turning a day keeps the doctor away!"
