glue vs anchor seal
glue vs anchor seal
glue vs anchor seal
>Can someone explain to me the advantage of Yellow glue vs anchorseal for sealing end grain. I haven't compared prices but that might be interesting. Titebond 11 might be better than plain woodworkers glue for slowing the moisture escape. I was just wondering if there was any advantage. Anchorseal seems to work pretty good but not as good as dipping the whole piece in wax. Any opinions?
Re: glue vs anchor seal
RussFairfield
>I know a woodturner who buys Liquid Nails by the gallon and swears by it as a sealer on large pieces of wood.
I suspect that it has to with porosity, and that a glue is less porous to water vapeo than a wax (anchor Seal).
>Russ I tried roofing tar, liquid nails, and latex paint in my early days and none of them seemed to outlive the other but my wood was stored in log form out in the open in those days. Consequently that is a worst case scenario. Whole logs+sunlight and wind is just asking for checks.
Pete in Holland, MI
>Haven't used glue, but the AnchorSeal is working well for me. Started using it in April of 2005 and bowls rough turned have not shown any cracking beyond what was originally there. At around $45 for a 5 gallon bucket (can buy it in containers as small as 1 gallon if I recall), pretty cheap too as compared to yellow glue at $15/gallon. Have coated over 100 12" diameter bowl blanks and don't think I've used much more than a half gallon yet. AncchorSeal is designed for the purpose, glue just happens to work for some folks.
Search for them on-line and you can have a bucket at your house probably by the weekend.
My 4 cents (adjusted for inflation)
Pete
JKJ in East TN
>Incidental to the wood issue, but a completely dried out Anchorseal brush can be put back in service in a few seconds while one with yellow glue might be beyond hope. Also, I'm a bit sloppy when applying Anchorseal, dripping an splattering on things, but it is pretty easy to clean up even when dried.
Ditto on the brush cleaning
Re: Ditto on the brush cleaning
MikeB
>I use glue and just store the brush in a container of water. Current brush has been in use over a year.
Ric Taylor
How do yo do that?
Ric Taylor
>My dried out, stiff brush stays that way. How do you bring it back to life?
Ric
Re: How do yo do that?
Pete in Holland, MI
>My anchorseal brush is washed with warm water after use. Waxy stuff really never dries out.
Pete in Holland, MI
JKJ in East TN
>>...My anchorseal brush is washed with warm water after use
I used to clean the brush, then I let it dry out one day. I found that a few swipes back and forth across the sharp edge of a scrap of wood or something was all it needed.
Ric Taylor
Thanks, I'll Try That
Ric Taylor
