Veritas - Innovation in Tools
Sealing blanks for AZ
Gary Evans Tallassee, TN
>Hi all,
I'm getting my stock ready to go to the Desert Woodturning Symposium in a couple of weeks and I'm curious if I should go to extra lengths to seal my blanks. I will probably use AnchorSeal, though I don't like the way it obscures the grain of the wood. I have used shellac at a couple of shows and like the way it looks, but it doesn't give much protection in an airconditioned space, so I don't think it's an option for the low humidity of the desert.
Years ago, I talked to the LumberLady out in Yuma about selling her some wood and she insisted that it be coated in yellow glue.
Since some of my wood is still pretty green, should I go for the extra protection of glue and not worry so much about the appearance? Mainly I want to make sure that the customer is not disappointed with the wood they buy. Any input from the desert rats would be appreciated. 8^]
Ellis, if this is too close to the commercial post restrictions, please feel free to pull it.
Thanks,
Gary
Re: Sealing blanks for AZ
Sean Troy
>Gary, If you coat with Anchor seal the end grain, the wood should be just fine. Thats how a lot of turners do it here in Arizona even in the summer when temps can reach 115 + . Humidity around February can be as low as 12 percent to 30 percent but the Temps are down around 70 in the day. You could wrap the blanks with a single layer of a Saran wrap type of plastic for travel and keep it on till they are ready to be sold. People know your wood is good so you won't have any problem selling with the seal coat.
Jim King
>If you have acess to a vacuum packing machine such as many people now have in their homes now you will have a nice presentation and perfect product. Next step down is shrink wrap but it is more delicate and tears easily when handeled a lot.
JKJ in East TN
>Gary,
If an outstandingly spectacular blank will be obscured and you have the time, you might try what we discussed once - slice a thin piece of veneer from one side and rub on some Watco oil to show the figure. Displayed with the blank, it may even make it more valuable! A number of similar blanks may benefit from just one sample.
Mark Kauder, Phenix City, AL
>Gary,
Since this is one time - short time problem for you, why not use that stretch wrap stuff?
Mark
Paul in Phoenix, AZ
>Gary it's dry as a bone here right now. Plastic wrap would probably be your best bet. I use it on pieces I'm working on until I bag'em up to dry.
>Hi John,
Actually I've been using your idea with the oak burl. The color and figure is so much prettier without the AnchorSeal.
Thanks all for you comments. I'm still flipping a coin as to my approach for this show.
Gary
