WE MOVED...
Burial Urns
Burial Urns
Burial Urns
Jim Dickman
>Looking for info and pictures of burial urns. I have to turn one for a family member. Threaded lids? Seal it? Size?
It will be set on a shelf and displayed - probably not buried.
Thanks so much.
Re: Burial Urns
Re: Burial Urns
Rick Allen
>Size is about 1 cubic inch per pound. Small folks will end up with fewer ashes. The ashes are HEAVY. At least much heaver than I expected. I wider base will help prevent a disaster latter on.
I have done two. The process, for me was very introspective. There are times during the turning of an object when my mind has a chance to wander. Like when sanding. The purpose of the object and the person who the object was for filled my thoughts.
This is the first urn I made for my Dad. He managed to live another 6 months which gave me a chance to make a second one which I liked better.
Good Luck
Richard
Re: Burial Urns
Re: Burial Urns *LINK*
Bill Grumbine (Kutztown PA)
>Hi Jim
I have done two urns, one for a pet and one for a person. The one for the person is pictured below. It was turned to the design specified by the son of the deceased.
It is made of walnut, and I went in through the bottom. It is closed up with a piece of 1/4" hardwood veneered plywood stained with a walnut stain and screws. Overall size is somewhere around 12" -13" high, and 10" in diameter. If you are interested, I wrote an article about the process which is on my website. The link is below.
If you have any questions, I would be glad to try and answer them.
Bill
Turning an Urn
Re: Burial Urns
Re: Burial Urns
Mike Brazeau
>I turned an urn for my mom's ashes last fall from some honey locust. At the time I Googled for information and images and went from there. I had the box of ashes and it had a volume of 220 cu. in. but the actual volume of ashes was just over 100 cu. in. I worked on the basis that I needed an internal volume of about 150 cu.in. which is roughly a cylinder 5 in. in diameter and 8 inches high. In the end I put about 3/4 of the ashes in the urn. I placed them in a plastic bag already inserted into the urn and then sealed the top into the urn with epoxy. Constructed just like a lidded box. The urn itself is outside dimensions 6" dia and 8 inches high plus top. Finished with about four coats of Minwax Urethane thinned slightly and wiped on. My goal is to make some small lidded boxes of the same wood for my three sisters and give them some ashes in them to sprinkle wherever they wish. It was a moving experience, but one I enjoyed as a final tribute to a great lady and mom.
Mike
