Bandsaw pulleys
Bandsaw pulleys
Bandsaw pulleys
Steve Woodall
>Hello,
Does anyone know what size pulleys are supposed to be on a 14" bandsaw?
I have an older model Rockwell model 14, I have been cutting blanks with it lately and it seems a little slow.
It also seems to stall very easily aven though it has an older 1 hp motor.
I am using 1/2" 4 hook tpi. Does that sound like the right blade for cutting blanks round after they are slabbed?
Thanks for any input,
Steve
Re: Bandsaw pulleys
Re: Bandsaw pulleys *LINK*
Mike Cunningham (Cape May)
>I assume the saw cut fine in the past. Therefore I'd suggest your problem lies with the blade. Try a 3/8" 3 tpi AS Timberwolf from Suffolk. I'd also check the belt tension on the pulleys and if the saw is stopping in a cut don't overlook the possibility of a bad capacitor on the motor.
Suffolk
