new turner
new turner
new turner
Rick in Washington state
>Hellow all, I have posted here for several years but only receintly have I purchased a new lathe. My question is,.. Is poplar a good wood for turning and or general woodwork. I have an oportunity to get what sounds like as much as I want. A freind fell several trees. My next question is how to store it and how long untill I can turn it or have it resawn?
Thanks to all who respond, Rick
Re: new turner
Re: new turner
Richard A. Gillespie, Jr.
>Poplar is good to both work with in flat work and in turning. It has several drawbacks though. It has a green to yellow coloration. It dents easily. It cannot handle water well and rots quickly.
I've used it as case frame components and drawer sides. I've never used it as the face wood. Personally I've not used it to turn, only because I don't have any on hand.
Re: new turner
Re: new turner
>I like poplar for drawer interiors as it is less expensive and machines well. I also like it for chair seats because it's easier to carve. It does dent easily though. Free wood is good wood.
Re: new turner
Re: new turner
>To save the wood, coat the ends with something like Anchorseal, or even Elmer's glue. You can paint them with latex paint or dip the ends in melted paraffin. Anchor seal is sold by UC Coatings I think and there are other brands available from Woodcraft etc. It gets cheaper rapidly as the quantity increases, so If you have a serious addition, buy a larger amount or share some with a local turning club.
Join a local turning club.
Keep the wood off the ground. and covered from the rain. Don't cover it tightly with plastic sheeting, let the it air dry, but wrapping it too tight will cause it to rot.
If you are cutting turning blanks, cut them 1 1/2 to 2 times as long as they are wide if you are not using them soon. They crack from the ends and this will give you a chance to cut them down and remove the cracked part later. Actually, leave them in the log as long as you can and then turn them when you cut them. Fewer ends means fewer cracks.
Keep reading and asking questions here at Wood Central. There is much to know about a lot of topics and while part of it seems obvious to those of us b\that have been doing it a while, much of it is strange and arcane to the uninitiated.
Poplar is a good wood to learn and practice on. Can be beautiful, not too heavy or hard and will have any of the same problems other woods have and you will learn how to deal with those as well.
Re: new turner
Re: new turner
Ed Karch
>Rick
Your address says Washington State. You may have Hybrid poplar or aspen or cottonwood. What you probably don't have is Tulip or Yellow Poplar commonly called just poplar. It is a memberof the Magnolia family and Washington State is out of its range. I live just outside Washington DC and have a backyard full of 100'+ tall 30"+ tulip pop.
Re: new turner
Re: new turner *LINK*
Rick Davenport
>Welcome Rick in Washington.
If you are in the Seattle area, you've go a great group to learn from.
Check out this link.
Maybe I'll see you at the next meeting.
A different Rick in Washington
(Edmonds)
Seattle AAW
