Lighting - More, More, More
Mark Kauder, Phenix City, AL
>Like most people, once I turned about 45 yrs old, it seems like I need more and more light every year. I have lots of flourecent lighting all over the shop. A couple of years ago, I added four 500 watt work lights in the shop - two pointing at the lathe. I have a couple of those Delta magnetic, gooseneck work lights, and recently I put them both on the head stock of my late to add light where I need it. But they have a warning sticker that says you should only use 40 watt lights in them. However, yesterday, I was in Home Depot and saw some of those curly flourecent lights that you can screw into a regular light socket. They only use 40 watts, but claim to put out the equivolent of a 100 light bulb. Seems to be great, really adds light where I need it.
Have any of you had any experience with them? How sturdy are they? I have been using "Rough duty" bulbs in the lights before this - seemed like the slightest bump would kill the regular bulbs.
Mark
Re: Lighting - More, More, More
Barry Turner
>I'm using a work light with a 200 watt bulb for general lighting in the area of my lathe. I have a couple of 8' dual-tube fluorescent fixtures in my shop. Then I have a Moffatt light with a 100 watt Halogen on my lathe. Works great, although the Halogen gets a bit hot.
Jerry Bickenbach
>Mark
I have been using several in the shop for quite a while (6 Mo) and have not had any problem. Have one in a clamp on type flood light and another one is a floresent reflector type (the curly glass is inside a glass reflector). There is no filiment inside so as long as you don't break the curly glass it should be okay.
Jerry
Nelson
>Hi Jerry, what are you doing up this late?
Jennifer@Indy.USA
>Mark,
I can relate to your "low light" situation. Seems I never have enough light either. It sounds like I have pretty much the same set up as you....however I have lately been noticing more and more that I get a lot of flicker/strobing on my pieces while they're turning and from what I understand it's from the fluorescent tube fixture overhead. Betty tells me that there is some kind of fluorescent tube bulbs that she uses that don't do that....but I can't think of the name now?
One of these days, I need to pop for the Moffat lights...at least one to put at the headstock. Right now I have a moveable light on an arm, but I've never used the curly bulbs in it....perhaps I'll try that? I think I have one in the bulb drawer. I'll take a look when I get home from work. Thanks for the tip.
Jen
Phil Joines
>The old tubes have a 60 hurtz (cycle) ballest. I think the newer electronic ballasts run at 400 hurtz. So they don't hurtz as mutch ;<)
JimQ
>The 40 Watt compact flourescent bulbs put out the light of a 150 watt bulb, and the heat of a 60 watt bulb. See if you can find one about 28 watts, they put out the same heat load as a 40 watt incandescent bulb, and the same amount of light as a 100 watt. They are rated for non-enclosed lamps rated for 40 watt bulbs.
JimQ
Dennis Thomas
>I have been using the "curly lights" for almost a year. I use both an equivalent 100 watt & 60 watt light. They are great in the summer as they don't generate nearly the heat of regular lights. Outside of the low temp. the other two items that maybe note worthy:
1. The 100 watt equivalent is longer than the regular light so it sticks out from my magnetic light cover. Just have to be careful not to hit, which I have done once.
2. I also use a 100 watt equivalent on a lamp that is attached near the tail stock end of the lathe. The lamp is adjustable but since the 100 watt light bulb is heavier than a standard buld, I'm having difficulty in keeping the lamp is it's position when it's extended; it want's to move down on it's own sometimes. I'm working on a fix for the lamp.
Hope this is helpful.
Dennis
Re: Puns at that time of the morning?
Basil Biberdorf
>You'll be happy with the curly fluorescents, I suspect. I've got them in several places around the house, and they work fine. Compared to incandescents, they aren't as susceptible to failure when being bumped as there's no filament to break. Secondly, they don't fail as quickly due to thermal stress. I think you live in a climate similar to mine (Houston), so that's not as big an issue as for our northern brethren. (In those cold climates, turning on a light in 40F or cooler weather always seems to make them fail faster.) You also won't be cursing so much when you brush your arm up against them. :)
Only thing you'll notice about the fluorescents is that, when new, it'll take 15 seconds for them to reach full brightness. As they age, it'll take progressively longer (like up to a minute or so).
Richard Allen
Richard Allen
>The fluorescent lights will add a lot of light. The light isn't a point source. A point source light is good for detecting scratches. I use both fluorescent lights and incandescent light. When I inspect during the sanding process I like to use a single an incandescent.
Re: Just another idea
Bart Rhoads
>I like the curly lights also. But I mounted a set of track light on a 1 x 4 and I have it hanging about 3ft over my lathe. With these you can direct your lighting where ever you need it and they will move up and down the track. I just dont have any mounted directly in line over the chuck. This gives me plenty of light. Works for me.
Carole Valentine
>Mark, I have found that flourescents don't show scratches and imperfections nearly as well as incandescent or halogen. Of course if you just want to use it for general lighting, it would be OK. I have them in my household lamps.
>As with all fluorescents, be very careful not to cut yourself on the glass if you break one. The white coating will cause a wound to take a very long time to heal.
I found a little halogen (I think) light at K-mart that clips onto whatever. It has a transformer and claims to run on twenty volts. Very bright light. Use it around my headstock. I have to find a source for the bulbs. Mine went out and K-mart did not have more. (DUH) They gave me one out of the broken display light. Nice of them. I looked up the bulbs on the INTERNET and they appear to be less than $2 and the one that burned out lasted several years. (rated at 3000 hours)
BTW, "rough service" bulbs have a heavier filament in them and I believe that if you check closely you will find they don't put out as much light as a regular bulb. Of course, if the regular bulb has a BROKEN filament, it does not put out any light. Some is better than none.
Also, In terms of general lighting, I think its true that it takes about ten times the candle power to be PERCEIVED as twice as much light. That's why task lighting is so important.
Ed Karch
>I use curleys in my Moffat. They sometimes catch shavings on the curl but are not hot enough to be a hazzard.
Re: Lighting - More, More, More - Thanks
>Well, looks like I made a good move then. Thank you all for your input.
To those that cautioned about not seeing sanding scratches with this type of light. You are correct. Long time ago, I discovered this, and since then - at least most of the time - I do initial inspection under a bright incondecent work light, and final inspection before finishing under bright sunlight.
Tip: even under incondecent light, you may not see scratches unless the light is what you might call a glancing light, i.e. at an angle to the surface of the bowl. This gets very tough in the bottom of a bowl. I purchased a "mechanics work light" from the Sanding Glove people. It is a small light on the end of a flexible shaft about 6" long. You can put it in the bottom of the bowl, and it really shows the scratches.
Mark
Carole Valentine
>You're right about the sunlight! If there are ANY imperfections, no matter how slight, Ole Sol will surely reveal them! Have to run up and check out the light - sounds like something I have been looking for.
Ric Taylor
Be Careful, Jennifer
Ric Taylor
>As you say, the fluorescent bulbs do illuminate with a flicker or strobing. Under certain circumstances, the flickering can sync up exactly with the rpm of power tools, such as a lathe or a table saw. This is the principle used by a timing light when tuning up an engine.
In those circumstances, the tool can appear to be not running, when it actually is running at high speed. The turning or the saw blade can appear to be standing still. Obviously, serious injuries are possible if you think your tool is off, when it really is on.
For this reason, I don't use flourescent lighting around power tools.
Ric
