We value your privacy.
>There are quite a few articles and discussion on Kiln drying lumber as well as an endless number of articles on Air, Microwave, LDD, and Alcohol drying of bowl blanks.
Has anyone tried to kiln dry blanks, if so can you tell me your process, results etc.
Are there any articles, books, etc that discuss kiln drying slabs or blanks etc.
I think you may have a hard time finding the info you are looking for. Kiln drying blanks thicker than 2" means that you are on your own as far as kiln schedules are concerned. Commercial kiln drying is primarily concerned with 1" to 2" lumber and the schedules are written accordingly. A schedule specifies what humidity and temperature the lumber can be subjected to at various moisture contents in order to extract the moisture as rapidly as possible while producing minimum degrade.
Once you go above the 2" threshold, the rate at which moisture can safely be extracted goes down geometrically. My understanding is that some folks are having good luck with Radio Frequency/Vacuum drying of thicker stock, but these processes require relatively large capital investments, and the technologies are being pretty closely held at the moment. Dehumidifying kilns will work for drying thick stock, but the time goes up considerably in comparison to thinner lumber.
"Drying Hardwood Lumber", which is available from the Forest Products Lab website gives you a pretty good primer on the kiln-drying process. Then it's up to the individual to extrapolate those principles to the process of drying turning blanks.
In my humble opinion, turning kiln dried wood is more difficult, dustier, and less fun than turning air-dried wood (which admittedly isn't usually as dry). KD wood just doesn't plane, cut, or scrape as well as air-dried stock, meaning tear-out and curly figured areas can be a problem.
While KD wood is essential in delicate segmented work with hundreds of glue joints, if you're lookig to turn a 1-piece bowl, the tried and true way is to rough turn them green, air dry, then finish turn when they stop losing weight and moisture content. To avoid checking, slow the drying process via partially sealing the end grain (or the whole thing), drying in bags or boxes, or experiment with some of the alternative drying methods such as denatured alcohol, boiling, detergent, etc...
That said, there are some professional production turners who use a kiln to speed up the process. However, they rough-turn the bowl from green wood and dry those in the kiln. David Lancaster in Maine is a good example of that method of work.
I will add that in terms of your enjoyment (at least MY enjoyment) turning bowls from dry wood in any form is nothing like the fun and ease of turning green wood. I often say "If you like turning dry wood, you'll LOVE turning green wood". The proeblem is in drying it... When you air dry your roughed bowls, the wood will cut cleaner, and with fewer problems than if you'd used a kiln dried block to start with.
The problem with the traditional, twice-turned bowl is our patience -- we usually want the result in a few hours, not six months ! If you get a lot of rough-turned bowls in the works, you can eventually finish turn them at the other end and enjoy more instant gratification from the second go-round. In this way, you get the sheer joy of turning green wood, as well as the round, stable shape of the finished bowl. The price you pay is the time lag from start to finish.
Another alternative is to turn bowls just once -- rather thin, and dry them in a bag, or microwave, alcohol, etc... and enjoy what mother nature has to say about the shape of the finished product. If this really isbn't your cup of tea, you could rough a large number and get them drying, and work up some once-turned green bowls to work on techniques, shapes, surface enhancements, or finishes while waiting for the rough-outs to dry.
I have a very good friend who is in the custom kiln-drying business. He will occasionally dry slabs and chunks as thick as 16/4, but not commonly; because these sizes are hard to find, they aren't cheap. There are shops that dry 3" and 4" turning squares, usually for table legs and such, but very few who will dry 4" thick bowl blanks.
>Brad: I would like permission to put your comments on my web site and take your pick of a piece of wood off my web site. It will be at your house in a few days.
Thank You for your inputs. Brad, in response to your question of "Why" I am not only interested in speeding up the process but also being able to use the kiln to control the drying process. Some of my previous blanks split and cracked from drying to fast so i was thinking that a kiln may allow for better control.
