Hollowform Problems
Hollowform Problems
Hollowform Problems
Allen Neighbors
>I don't have a laser system to observe the thickness of walls on my hollowforms. When the entry hole is too small to see past the tool shank, how often do you stop, clear it, and measure? Every pass? I always say, "Alright, on this one, I'm going to get it really thin." Then, when turning it, I get so afraid of cutting through the side, that I always stop before I get it as thin as I want it.
How long should it take to turn, say, a 6" tall, X 4" wide hollowform? Thanks, Allen
Re: Hollowform Problems
>Allen At first I just cut and clear debris. I use a series of cuts that stair step so I can tell where I am. I learned this from John Jordan but I think David Ellsworth and some others teach the same thing. This allows me to clear away most of the enterior.
When it starts getting thin near the top I measure using a bent coat hanger just about every time I stop to clear out the debris. I will continue this as I work my way down the side. If I'm turning it really thin I stop fairly often to measure.
I turned one today about 5" tall and 4 inches around. Took about an hour and a half but I had to stop in the middle to answer a phone call and then I worked on my grinder some more to modify it slightly. I would guess it took about an hour. If I turned them regularly it would take a lot less time. I know it used to take much longer.
Re: Stair step cuts
Allen Neighbors
>If I understand it right, you have thinnest-wall at the top, then it steps out to a thicker-wall area, and then another step out as you get deeper inside the hollowform? You use these "steps" to sort of "feel" your way with the cutting bit inside the form? That makes sense to me now, because when I'm turning through a narrow opening, I can feel the bit make contact with an uneven area.
Only you make the uneven areas radically different, so there's no mistake, right? I'll give it a try. I just get the idea that I'm slower than the 7-year itch.
How can I get in about 10 years experience in the next 10 days? :o)
Thanks,John. I appreciate your kindness and your patience.
Allen
Re: Stair step cuts
Ed Karch
>Do two or three a day and blow up a few. When you think you are close saw it in half and check. In ten days you will be right on the button every time.
Re: Stair step cuts
Allen Neighbors
>(Loud Scream Here) I can't even imagine sawing one in two. I ruined a Christmas tree ornament that I was trying to hollow, and nearly had to get counseling. :o(
:o)
Maybe you're right, Ed. Maybe I oughta get radical and waste some wood. Somebody told me the other day that it grows on trees. I'll see if I can drum up the nerve.
Allen
Juergen
>Get a prctice piece. Drill a half dozen 1" holes in the blank that will penetrated the planned shape. Hollow using the techniques John described. Now you can watch the cutting bit as it gets closer to the final thickness. In this way the brain can commect with what's happening inside the HF. You'll find the next one easier. You can also try it just be feel and focusing on the angle of attack of the tool's cutting edge.
>Two very good answers. Ed basically said to turn a bunch. The more you turn the more comfortable you get with hollowing. I haven't been hollowing big work for a year or more so I'm turning a bunch of smaller stuff to get comfortable with it again.
What the stair step does is make it easier to "feel" where you are inside. By squeezing your left hand you can pull the cutter a known amount each time and create another set of steps.
Juergon's method of cutting holes in the side is a great method for learning. If you don't want to do that just get a piece o wood with several good defects in it.
Re: Stair step cuts
Ron in Drums PA
>Allen, the smartest thing I did was cutting a hollow form open in a way so that I can still chuck it in the lathe. With the lathe off, I inserted my tool into the form and see how the tip was working.
Remember the stuff we turn grows on trees
Ron in Drums PA
>That is a great idea Juergen, thanks.
gtwilkins
>Juergen, Thanks what a great idea, I have just started hollowing and need to see what's happening. I've turned weed pots with oysters inlaid so it the holes could be plugged and used as decoration for the first 30 or so!
I am making my own tools as I am on a strict budget after ordering a new DVR XP so I need to see how the cutter is working after having a couple of heart stopping catches and a stuffed up thumb. Trevor
open form
>One thing we haven't mentioned is turning an open form with a large hole or you might call it a vase. Instead of using your gouge use the hollowing tool. You can look in and see what you are doing and when your done you have a vessel you can still use. Of course you'll have to sand inside but that's a good learning thing also.
Allen Neighbors
>My thanks to all of you that posted instructions. I appreciate them, you've given me some good things to try. I like the idea of drilling some holes in a practice piece, and the large opening vase is another one. I saw a short video where the turner cut open a form to show how the tool was cutting, too, so I may try that also. I've got some sorry cottonwood that I might try that on.
Many thanks to all you WCers!! This is the best forum ever. Thank you, too, Ellis.
Allen
Brad Vietje
Cutting Through The Side
Brad Vietje
>I find that getting one as thin as you dare, then intentionally cutting through the side is very revealing. Listen carefully, and you will hear how the sound changes as it gets thinner, and thinner, then fails, and learn to recognize that sound change when doing one for keeps. This is a good education, and you can do it with some less than spectacular wood at very little $ or emotional cost.
Safe Spinning,
Brad Vietje
Newbury, VT
