We value your privacy.
>After I have coated everything down with Anchorseal, should I doing anything about this coating when I get ready to turn? I assume that it will go to the floor with the shavings, without a need to worry.
>Just turn it away. It's water soluble, so it is biodegradable. Those shavings will burn faster than the others, but there won't be enough to be a hazard.
Are you sure it's water soluable? It certainly stays on logs and blanks that I leave out in the rain. I understand it is a emulsified wax, something like putting soft wax and water in a blender and whipping it to a frenzy. It has a chemical added to keep the wax from separating and floating to the top of the water. (Old or frozen anchorseal will separate this way, according to the maker.)
UC Coatings indicates it is non-toxic and non-hazardous. Some sources indicate it is made from beeswax but I haven't seen that in the literature. It cleans up with soap and water. It does make for a slippery truck bed when I'm sloppy about applying, but that's not "hazardous", that's my own fault!
BTW, I've tried a lot of things and I've finally found a good way to handle and apply Anchorseal in small to medium quantities: I use a plastic 2lb Folger's coffee "can" which, my wife tells me, has won some kind of ergonomic award related to arthritis sufferers. These cans have a great hand-hold molded into the side for an easy grip, and a soft, easy-to-remove plastic lid. I pour a couple inches of Anchorseal in the bottom and apply it with a cheap 3" disposable brush. I store the brush in the can with the lid on and it's always ready. (Note that if your Anchorseal brush ever does dry out, there is no need to clean it, just brush it back and forth a few times on the edge of a board to loosen up the bristles.)
>The reason I said it's water soluble is because when I talked to the sales rep from UC, he said it was a wax-water mixture. Also, it doesn't stay very well on my wood that I leave out in the weather. It lasts for a while, but after it rains, I notice that it has really thinned down from what it was before the rain. I've had to add another coat to some of my logs that aren't protected by the rest. Also, hot soapy water removes it. I don't know what chemical additives are in it, but you're right, it is non-toxic.
I dunno. Maybe it's heat soluble. It could be the infernal heat that we have here, that breaks it down.
>I have noticed that if there is a lot of it, the shavings are somewhat sticky. They stick to the floor and your shoes and tend to track all over the place (into the House) This may have been made worse by applying Anchorseal in the shop and getting the excess on the floor. Not a good idea.
