THE WOODRAT IS BACK!
Carole V.
Carole V.
Carole V.
Oscar
>Carole, I'm interested in learning the technique you use for finishing that uses lacquer and and tung oil. Could you please describe this method. Thanks, Oscar
Re: Carole V.
Re: Carole V.
Oscar
>Carole, I previewed next weeks chat turnings, outstanding work.
Re: Carole V.
Re: Carole V.
Carole Valentine
>Hi Oscar. Sorry, I forgot to email you! It's fairly simple. With Waterlox, you can have anything from flat to gloss depending on your taste and how much time and effort you want to expend. The most important part is preping your wood. Any imperfections like sanding scratches, tearout, toolmarks, etc. will literally leap out an grab you if present, especially if you are going for gloss. I sand up to 800 and inspect closely. (Sanding is an art unto itself, and the most difficult part of the turning process for me simply because I have "old" eyes!) Then I use a 50% thinned lacquer (Deft) and wipe it dry immediately. Let it sit overnight then lightly buff with 6/0 steel wool. Wipe it down, blow out any "features" like knots, cracks etc. to get rid of all dust and wool fragments. Apply a coat of Waterlox and wipe dry - DRY!. Let sit overnight, Buff with 6/0, etc. Keep repeating. Usually on the third or fourth coat I hit it with 4000 micromesh. On the Fourth or Fifth coat (or whatever I decide is the next to last coat) 8000 micro mesh then 12000. On the last coat I do not wipe it dry completely but I smooth it with my hand so there is just a slight even film (this can be tricky). Let it cure completely. I wait a week or so. Buff. Apply Rennaisance Wax. This is sort of a general thing...it all depends on how I feel, how much gloss I want, what the wood is like etc. No two pieces are ever done the same, it seems! I highly recommend Russ's finishing videos. He does it a little differently and uses his home brew with similar results. Plus there is a ton of other excellent info on finishing turnings.
Oh,BTW...all of this takes place in my kitchen where the temp is about 68 degrees. Both wood and finish are room temp.
Re: Carole V.
Re: Carole V.
Oscar
>Thank you, Carole! Oscar
