THE WOODRAT IS BACK!
Best way to cut crotch wood???
Steve Woodall
>Hello everyone,
What is the correct way to cut crotch wood to show the feather grain?
I have a few Walnut and Black Cherry logs that have crotches, and I would like to know how to process them into good turning blanks.
Thanks for the input,
Steve
Re: Best way to cut crotch wood???
GaryG in MD
>Steve, You'll probably get some better answers here, but for starters, try page 17 of "Turning Green Wood" by Michael O'Donnell. IMHO, this is a book everyone should have on the shelf. ...Gary
George Van in WI
>Steve, I chainsaw both sides of the centerline of the three piths, mount between centers and rough. I used to cut dead center for two platters but then I was turning some of the best flame figure into shavings. Dave Winters taught me this method and I have been using it since. I would rather have one good than two halves.
>As mentioned above, I cut them right down the "Y", Trying to literally take all three piths out in one pass with the chain saw and then make them into shallow bowls or platters.
I have not had much luck with Cherry. Just have not found a spectacular Feather in any cherry yet. In walnut what I get is a pretty good feather, but I end up with a lot of mixed sap and heart wood. Just not sure whether I like it or not.
I tried cutting a vessel out of walnut crotch by turning a piece with the main pith of the tree ending up in the vertical position running right up center of the vessel. Again, the white sap wood was coming out on the top of the vessel. I was not liking it and rushed it and cut through the side. Trashed it.
John H Williams
>PIC is a honey locust vessel that was taken from a crotch and turned with the "Y" of the crotch as the top of the vessel. I cut the two slabs off the branches to effectively remove the piths. The flame grain is within the sap and the heartwood on opposite sides.
Gary in Zirconia, NC
>Black Walnut, 17 inches, not much sapwood in this one. But the ants were after it! I like to go right down the pithes with the chain saw.
forgot the photo!
