A55 Smoothing Plane
Turning Pool Cues
Turning Pool Cues
Turning Pool Cues
Ryan Dicker in Renfrew, Ontario
>Hi,
I was wondering if anyone here has had any experience turning pool cues. Mainly, I was wondering which types of wood would be preferable and secondly where the parts required for one can be purchased.
I figure a steady rest wouldn't be a bad idea while turning this. There is also a CNC lathe at my school so I could use that as well.
Thanks for taking a look,
Ryan
Re: Turning Pool Cues
>Ryan Do a search of pool cues on the web. There are a lot of good sites that discuss wood types and how to make the cue. Unfortunately I have never bookmarked them.
JKJ in East TN
>Ryan,
An old FWW magazine (#59, July/Aug 1986) has an article on making a pool cue. The author related his experience with using the first cue he made from ebony, rosewood, maple, purple heart, mother of pearl inlays, etc. Beautiful but worthless. The first break shattered the cue and drew blood!
For the cue he discussed in the article, he laminated a handle blank from a maple core (rosewood for a heavier cue), ebony side strips, and padauk corner strips. Turning the handle exposed long elegant maple tapers. Maple for the shaft. He made the threaded rod and double-threaded connector using taps and dies, and turned collars from delrin stock and ebony. He did use a steady rest, rigged from a pillow block bearing. He said he always turned cue shafts in stages, letting the wood "dry and settle", sometimes for weeks between each stage so he would end up with a perfectly straight shaft. He purchased the fiber ferrule, tip and rubber bumper. Most of the turning seems to be with a 1/2" skew.
If you can find this old article it might help or at least be very interesting. Evidently the author "Colorado Slim" was a retired pool hustler. :-)
John Leonard
>Ryan try these sites www.cuesmith.com and www.cuestick.com (for supplies). I understand that cues are usually turned on metal lathes because of the precision required. We had a young man come to our last club meeting looking for the same info. Nust be cues turning time. John Leonard
Re: Turning Pool Cues *LINK*
Mike Brazeau
>I came across an article the other day in an old issue of the Chip Flyer, the news letter of the Golden Horseshoe Woodturners Guild in Burlington. Check into our new web site and send a note to the president and I will scan and send you a copy of the article. We don't have a lot on the site yet but it is a start.
Mike
GaryG in MD
>For materials, search eBay with something like "wood cue" or whatever. I recall seeing a lot of exotic wood turning blanks sized particularly for pool cues. ...Gary
Lee Valley sells the joint hardware
Garrett in Victoria
>Thanks to all that responded.
This project is beginning to look like more of an undertaking than I had originally thought.
From what I have read, the shaft is best made by laminating strips of rock maple veneer and then turning it in succession to prevent warping. Anyone have a rough idea how much rock maple veneer goes for here in eastern Ontario?
I had seen those couplings from Lee Valley, but I'm not sure how precise they are. Im thinking I would need to make some sort of jig to hold the cue while putting the tip on, as everything must line up perfectly.
Thanks again,
Ryan
