REAL MILK PAINT
Delta Lathe Blues
Delta Lathe Blues
Delta Lathe Blues
Steve in NC
>18 months ago when I started turning, I purchased a Delta 14" Iron Bed lathe. ( If I had known about this site before buying it I would have gotten better guidance.) Since first using it, it had a vibration at certain speeds. I tried aligning the pulleys, adding weight and calling tech support with no success. Since it was the only lathe I had used, I assumed that it was just the way lathes were.
(After getting a Jet mini for Christmas I learned how smooth a lathe without vibration can run.)
Anyway, last night, I was finishing up a couple of pieces for my first public showing this weekend. I was using the Delta due to the size of the piece when all of the sudden there was a loud bang and the sound a grinding metal. I took off the belt cover to discover that half the variable pulley on the motor had exploded.
Needing to finish the pieces for the show, I removed the rest of the pulley, and installed a 2" fixed pulley I had in my parts box. I adjusted the other pulley to get proper belt tension and luckily the speed was perfect. The more amazing thing is that the lathe ran with almost no vibration!
So now I am wondering, is it possible to install two stepped pulleys and eliminate the speed control or is it possible that a new pulley will solve the problem. I called tech support but they offered no help and refused to warentee the pulley.
Any thoughts out there.
PS - I set up the show this afternoon in the gallery of our church. Sold three pieces while I was putting it up.
Re: Delta Lathe Blues
Ed Kelle
>I know what you went thru, I have the same lathe, and had the same issues. Replaced, belts, had warranty shop "fixes" finally a new motor and headstock, but the same vibrations. Those pulleys make a racket and having a single bearing doesn't help either. I think a new variable pulley will just bring back the vibrations.
At least you got yours running smoother now, heck if you can get it to run good on a low speed or two, I might think of doing this "upgrade" to mine.
I also got a Jet mini and it is a world of difference. I only use the big one when I absolutely have to. And luckily I still have the original headstock to use for parts, and I have.
Yes, I am dreaming of the day when I can afford a 3250 and turn this delta into a boat anchor.
Congrats on the sales!
>Steve I had the same problem with my Delta 46-700. I replaced the pulley 3 times and still had vibration. I think it's the pulley design or something similar. I'm not familiar enough with your lathe to answer the question on the step pulleys.
Gerry Meekins in Maryland
>Steve,
I had the same lathe and all of the same problems. I bought the lathe to turn spindles, which I think it would do well, but I never turned a spindle after I tried turning bowls.LOL I replaced all of the drive train and was able to get it to run smooth but never quiet. I ran the lathe the last year I had it with a three pulley set up on the motor and it ran quiet and smooth. Look at this as a learning lathe. Looks like to get a variable speed lathe you would need to spend about two to three times what the Delta cost. You may be ready!
Gerry
Re: Delta Lathe Blues RE to Gerry
Steve in NC
>Gerry
Did you put a three step on the Spindle as well. If not, how did you get the belt to align when you changed speeds?
Jack Savona
>My 46-715 had reeves drive problems, mostly noise, for quite a while. Delta has always stepped up to the plate (minus out of stock delays) with the parts...right up to the end of my 24 month warrantee. If you've only had your lathe for 18 months, Delta should honor its 2 year warrantee. I'd push them to honor their agreement. I don't call "technical"; I call "parts" and order what I need (and want). So far, no cost for two reeves drives, bearings, guide shaft, 2 handles, 2 banjos....
I should've gone with a Jet.
ben d.
>There has been instances of the key in the motor shaft is not the correct size key for the sliding pulley. A set screw holds the stationary side of the pulley in place and when the outer pulley travels if the key is too small then the pulley can set up a chatter and viberation. The sliding pulley bore can be oversize and cause the same thing. Any over size would cause the pulley to cock when moving and to wobble when stationary. Don't know what the tolerance is supposed to be but these 2 items most likely is a large part of the noise and viberation. Since the unit ran quied and smoothe when you put a stepped pulley on the motor suspect the problem is in the drive pulley and not the driven although it should bear the same inspection.
Hope this helps.
>No Steve,
I was a bad boy and left the belt cover off. When I changed speeds I would just turn off the lathe move the speed lever while turning the spindle until the belt was loose enough to move to the next pulley. And then I would retighten by moving the headstock speed lever again.
I initialy lined up the center pulley but never worried about the other alignment. Worked pretty well and never wore out a belt.
Hope this helps.
Gerry
Steve in NC
>Gerry
Thanks for the input. I was thinking along the same lines. If I can Delta to give me new parts, I will give the original configuration another try. If it still vibrates I am going to use the stepped pully routine. Since I only use the Delta for larger items, I thnik I can live with three speeds.
I have also aquired three solid core fire rated doors that weight about 100 lbs each. I think I will make a heavy soild bench and see if that helps.
Steve
>Steve,
By all means get all the free parts from Delta that you can. They are still making this lathe and they should be aware of the problems by now.
Good luck with it!
Gerry
Here's an idea...
Peter Teubel
>I don't remember where I got this pic, but maybe it'll help a bit.
tek-Brunswick, Ohio
>Those fire rated doors are nice and heavy. They are probably filed with gypsum. The only places that will hold screws well is where they put backing in them. That would be around the edges and where the lockset was and maybe at the top if it was preped for a door closer. They are still rigid, but plan bolting all the way thruogh them where you need a strong joint. They are not as heavy as the lead lined doors we hang in radiology suites. Those take two of us to hang.
Tom
Re: Delta Lathe Blues UPDATE
Steve in NC
>Hi folks
Thanks to the advice I received from this group, I called Delta today and they are sending all the parts I need to fix my Delta free of charge - no questions asked. (I immediately canceled my other parts order for almost $75.00)
While I am unhappy with the vibrations in the lathe, I am quite impressed with the customer support.
Thanks to all those who recommended that I go the customer service route rather than tech support.
Don Tewell
>I recently purchased a Delta 46-701 (used) and was surprised at the noise. I have notice some vibration but not enough to cause worry, yet. But it is something it keep in mind if the vibration gets worse as it gets older. Thanks for the tip(s).
evo
>I have had the 46-715 for just about two years, and simply put up with the vibrations, which have been very frustrating. Two months ago the inside portion of the variable pulley on the spindle broke (the center of it just sheared away), so I'm going to try the stepped pulley idea from Gerry because the new pulleys from Delta are STILL on back order. Someone said it's since Black and Decker bought them...who knows. I also spent the w/e fully bracing the sheet stand with 3/4 inch plywood and adding 450 pounds of concrete bags on the new shelf that I have on the lower bars of the factory stand. Hoping these changes help. I'll let you know. Any suggestions on where I should get the stepped pulleys or what type (aluminum, cast iron, etc.)? If this doesn't lessen the vibrations I'm going to save my pennies for a OneWay or similar and leave this one for the scrap heap, or maybe a dedicated polisher. Thanks in advance.
evo
Mark Wollschlager
>I am in sort of the same boat.
My 46-715 has been picking up vibration over the last couple of months.
I have loaded the base with sand and steel with only a small improvement.
My wife got me a Jet VS mini for my birthday to help me out, and stop my complaining. It has been a treat all by itself.
I have established a 'Stubby Fund' to be cashed in at some time in the future hopefully for a Stubby.
Practically the fund will pay for what ever I can afford when need overcomes patience. :-)
Its too bad, the Delta has been reliable and has some nice features that cost a lot more on other lathes.
Mark.
Re: Delta Lathe Blues *LINK*
Phil Joines Krum, Tx
>Don't know what size you need but you can probably find them here.
The spring loaded VS might be a way to go.
MSC pulleys
evo
>Thanks all. For the record, Delta finally got their pulleys in stock, and sent them to me express...and covered the warranty, which was still in effect when the machine failed but had expired by the time we called. They were fairly easy to install. There's still some mild vibration, but everything's working again. I'll keep my "higher end" lathe fund going, but won't break into it just yet. Seems this one will carry me for now.
