Bowl Blanks
Bowl Blanks
Bowl Blanks
George Fitzpatrick - Springfield MA
>I got tired of trying to work with the most common woods I can find around here...maple and oak, mostly oak. So, I went on Ebay and bought some turning blanks of various species, walnut, cherry, elm, cedar and (?) canarywood...these blanks are mostly 6x3, 5x3 or 4x3 rounds. They were listed as green and sealed. So I get the first couple packages and they are exactly as advertised. I have begun to turn the rounds into bowl blanks. I am turning them down to about 5/16" thickness and then putting them into grocery bags filled with the chips from that particular blank. Close them up, date them, and put em on a shelf in my basement for drying. I plan to go back in two or three weeks to start checking them out for dryness and readiness for final turning.
Am I doing this correctly?
Re: Bowl Blanks
might try alcohol
Darryl Hansen
>search for David Smith's process
Re: Bowl Blanks
Re: Bowl Blanks
>My experience is that no matter how you dry them, they warp. Some methods dry and warp them faster, some maybe cause a little less warping, but no matter, they warp. The usual rule of thumb is to turn the blanks on a 10 to 1 ratio. 1" of thickness for each 10" of diameter. So a ten inch bowl would be rough turn to a blank that is about one inch thick. I would be a little nervous about turning any blank less than 3/4 or maybe 5/8. Once you rough the blank, you bag them or coat them or whatever you think will work for you and wait.
Another rule of thumb is to wait a year for each inch of thickness. This is where the various drying techniques came from. Alcohol, microwave, dish detergent, kilns, desiccants, etc. Who has a year?
My experience is that you can weigh and bag them and wait a few months. Weigh them occasionally. Use a good scale, like a postage scale. When they stop losing weight, they are ready to turn again. I'm not in a dry climate (Humid Southside VA) and I find they dry enough in about four or five months. I find that that takes out about ninety percent of the warping. I find the warping does not usually bother me and I turn many green to finish in the same day and let them warp. You either like it or you don't, and it depends on what you are doing. (I made some column bases for a man out of his extremely green poplar. What started as 12" in diameter circles ended up about 12 1/2" by ll 1/2" ovals. Not good. Not happy, but he had been warned, I Had saved the sketch I used to explain it.)
So, after all this blah, blah, blah, I think you are on the right track, but it sounds like you roughed them too thin. If you make then 5/16 and not 5/8", I doubt you will be able to mount them and true them after they dry. I would suggest you mount them as they are and finish them before they warp and see what they do. Rough your next batch thicker.
Where are you? I have a family farm and we have harvested some trees. If you were willing to come get them, I can give you lots of walnut, hackberry, cherry and more of the dreaded oak. Email me if you are interested.
Re: Bowl Blanks
Re: might try alcohol
>Darryl:
I am planning on taking a couple of the blanks and trying the alchohol method as well. Trying to find the best way to do this. A learning experience, for sure. But I'm getting some good practice, just turning from the rounds to the blanks....
Re: Bowl Blanks
Re: Bowl Blanks
>Barry:
Thanks for the info. I actually was afraid that I was leaving the blank walls too thick. On the next couple, I will try leaving them at about 5/8 and see what happens.
I am in the Northeast...good old new england, full of oak and maple and most of all, pine....so I have not found that much variety. I have been trying to learn to turn oak with some consistency...but that is a struggle. I will keep up with that, but want to get some variety in my turning, which is why I looked at the stuff on ebay. It certainly is more expensive that way, but at least it's available.
Re: Bowl Blanks
Re: Bowl Blanks
Skip Beardsley
>Oh, what I would give to be back in NE and be able to turn some hard maple. We have some birch here in northwest Montana and little else of turning value. I know there are several hardwood dealers in the Boston area where you can buy 16/4 lumber on many varieties. Also you can go direct to some to the smaller sawmills in Vermont and get dry lumber to cut into blanks.
From my view, I agree with others, you are truning too thin for the twice turned bowls. Won't be able to true them up when dry. The one inch rule is a good one to follow.
Re: Bowl Blanks
Re: Bowl Blanks
Jim King
>I can speak as to tropical species only . In my opinion tropical species should be rough turned the moment you unpackage them. Many people buy tropical woods and as it is unusual and beautiful they want to be extra careful and let the blanks dry prior to turning. This is absolutly the wrong thing to do. When you receive it rough turn it and the shavings in a bag is not a bad system if you have plenty of time . We boil all rough turned tropical peices with very good luck and they dry very fast with little or no degrade.
Re: Bowl Blanks
Re: Bowl Blanks
Don Tewell
>Being fairly new to turning, I rought turned some cherry about 3/4 inch thick for an 8 inch bowl. Bought a cheap cooking pot at the local store and boiled it for about an hour. Wrapped it in a towel for 2 days, stuck it in a grocery bag and taped it shut. Set it on the shelf for 90 days and re-turned it. Has had no warping since. Lot of time and trouble, but it works. Haven't tried to DNR method, yet.
Re: Bowl Blanks
Two things George *LINK*
Dave Smith, Longview, WA
>Hi George,
I have not been any where in this country that people don't plant yard trees and fruit trees. By yard trees I am referring to trees that are not native to the area. Don't over look lilac, rhododendron, dogwood and other ornamentals. I will bet you can find apple trees in any old farm.
If you have already rough turned the bowls to 5/16" I would recommend that you soak them in alcohol ASAP and dry them per my procedure. I have found that 1/2" is a good thickness for bowls up to 8" or so. The 1" rule of thumb does not work well with the alcohol process. The thicker the walls the more stress there is across the walls and thus the increased likely hood of degradation not to mention the increased drying time.
I have more information and links on my web site. There is a link to an alcohol soaking blog in the upper corner of my web site that I would like to keep more current if I had some extra time. There is some interesting feed back from some turners who are using the process that you may find helpful.
Dave Smith
Head wood pickler in Longview, WA.
Wood n Heart
Re: Bowl Blanks
Brad Vietje
Re: Bowl Blanks
Brad Vietje
>Hey George,
You have to seek out some local sources... since you're in Springfield, you might check out the Central New England group (I think they meet in Worcester), or the group in Central Connecticut. There are fine turners in each that would make great mentors, and surely someone not so far away knows of some local sources.
I'm a consumate scrounge, and I often work in your area. I got a real nice Dogwood trunk section in Chicopee, and some Yew, Sycamore, and Norway Maple Burl right on Rt. 5 in Hatfield... Keep your eyes open for power companies that trim trees near the lines, and ask the landowners -- you can usually get some good stuff that way.
BTW, if you ever see anyone near that phenominal burl-covered Elm tree in front of the Springfield City Library -- CALL ME COLLECT !
Safe Spinning,
Brad Vietje
Newbury, VT (about 175 miles straight up 91...)
