Side Grind Bowl Gouge
Tomm
>How is the side grind bowl gouge technique different from a regular bowl gouge when it is used inside a bowl? Thanks for your comments.
Re: Side Grind Bowl Gouge
Woodnut358
>With the side grind,as the Ellsworth,because of the long sweep on the sides,you can pretty much use one tool to perform different tasks.You can rough out,shear scrape,and by holding the handle low and using the bottom edge,you can wind up with a nearly sand free surface.
Don Tewell
>Only after MUCH practice. I just got the signature bowl gouge for Christmas and haven't had a 'sand free' area yet. But I keep hoping. It is a great tool.
