Jet Mini coming to a halt
Blake Washburn
>I was turing in my Jet Mini and it came to a sudden halt. My spindle gouge caught and put it to a sudden halt. Its not hard to stop the lathe while running now. I can stop it with my bare hands. (with alot of trouble) When it caught, did I hurt the motor severly? Is there a way to prevent that?
Blake Washburn
Re: Jet Mini coming to a halt
Dennis Y
>Check your belt tension. A sudden stop shouldn't damage the motor. If it did my mini would run either. Dennis Y
Keith Tompkins
Keith Tompkins
>Hi Blake, agree with Dennis. However, keep the area around the motor free from chips. They will accumulate and cause the motor to overheat...THAT will kill it!
richinva
>don't know about the Jet, but my Rikon has set screws that hold the pulleys on the shafts, and they WILL come loose.............
Rich
jwoodwright
>Blake, when you say "I can stop it with my bare hands"... Are you using the Handwheel as a brake? If so, the handwheel is the outside spindle holder. Too much tension and the motor is stressed and heat's up, too little and there's slop in the spindle. There are two set screws and a LEFT Hand Thread on the handwheel. That sudden stop and loose setscrews could have reset the handwheel.
Hope this helps... John
time for a new capacitor?
Bob Elliott
>You mentioned, "...not hard to stop the lathe while running now." If that's the case, you probably need a new capacitor for the motor. Same thing happened to me in that all of a sudden there was loss of power and I could stop the spindle while running by simply grabbing the handwheel.
