We value your privacy.
I don't think there is one best way. If you will use the wood fairly quickly, sealing and storing outside is good, especially in the cooler months. The wood will remain good and wet and you can decide how best to cut it up as you use it.
I like to process some into blanks and coat all over with anchorseal to slow the drying. If making bowls, it's probably best to rough them out as soon as possible.
For longer term storage, cutting into slabs and air drying is probably better. However, you have to decide how thick to cut the slabs - thicker gives more options but dries slower and may crack more.
I cut some into blanks, but then I've immediately limited myself to a fixed use. If I cut a bunch of round bowl blanks, what if I decide to make boxes or table legs. Leaving the wood in slabs postpones that decision.
However, the smaller pieces do dry more quickly and degrade less. I try to cut logs into a variety of shapes and sizes - some into larger bowl blanks, some into spindle blanks generally from 2" to 4" square and as long as possible. I coat the endgrain of everything and coat bowl blanks all over. I see very little degrade.
Also, I think it is possible to get carried away and have TOO much wood on hand! Much of it will end up going to waste. Best to share a bonanza and someone will proably share later. Our turning club is a great place to take excess wood. Also, you might be able to sell extra processed blanks. The local Woodcraft dealer told me last week that he does a good business selling turning wood for people.
>I had a forestry friend tell me to stand the logs on end until I was redy to cut them.
I've had really good success doing this. SOme have been stored in the garage and some were stored outside. Generally, I'll lose a couple of inches to checking, but nothing major.
>My neighbor (a woodturner) showed me how to store bowl blanks a great way.
1. Cut bowl blank to size.
2. Heat a deep fryer (250 degrees) with blocks of wax in it.
3. When melted, get a paint brush, and spread generous amounts of melted wax over the blank. Let dry and if needed add another coat.
I did this to a nice piece on maple that John Lucas gave me. It was about 12" diameter and my neighbor said that it would last me about 6 months or a year!
>>...spread generous amounts of melted wax over the blank
Blake,
You might also look into a liquid green wood sealer such as AnchorSeal. This is an emulsified wax, sort of a wax in a water suspension. You don't have to melt it, but just paint it on cold. It dries, leaving a thin coat of wax. You can buy it in small quantities at Woodcraft and other dealers. (I recently bought a 55gal drum for my sawmill and to share with club members) Melting wax could be cheaper than buying Anchorseal, however a gallon will do a LOT of bowl blanks.
If you melt paraffin wax, be very careful since it is highly flammable. It is generally recommended to melt it over water in a double boiler. Otherwise, it might be better to melt it outside to avoid burning down the house.
>I am experimenting with vacuum packing blanks. No mold ,no cracks after 8 months. If you have one of those household vacuum packing machines try it on some fresh small peices.
