Vac system: swivel coupling bearing
Pete in Holland, MI
>Hey all -
Building my vac-chuck system and working on the swivel coupling for my Jet1236. Is one sealed bearing adequate, or is it better practice to use 2?
Thanx.......
Pete
Pete in Holland, MI
>Hey all -
Thanx.......
Pete
Re: Vac system: swivel coupling bearing
Stephen Mushinski
>Pete,
Since you will have a load pulling down on the swivel it would be best practice to use two in line.
Steve
>I've been using just one for about 4 years now. Still works great. John
Built one last night with 1 bearing
Pete in Holland, MI
>All I had available was one sealed bearing, so I built one last night. Seems to work well. Let it run on the lathe for about an hour and didn't do anything it shouldn't have. I agree 2 bearings would have been better than one.
Building the vacuum chuck currently, the last piece in the vacuum chuck project. System is complete and on the wall. Hope to be finish turning bowl bottoms with a vacuum system this weekend.
Thanx for your help !
Re: Built one last night with 1 bearing
Steve Mushinski
>Pete,
You asked which way it should be done, not which way it can be done. The one I made also only has one bearing as it was what I had handy. For the amount I use it, I think it will last me for life. - Steve
