We value your privacy.
I'm looking for material to make a few more small hollowing tools. I need 1/4" square bar steel and 1/4 HSS square stock for bits to silver braze onto it. I know it's been posted here...where to buy it and even part numbers I think...but my searches of the recent and archived stuff is coming up empty.
While I've got your ears....it is cold rolled I want for the shafts correct?...also....do you think 1/8" bar would be too small for use on a tool shaft that would be probably only 4" long....for use in making miniature hollows?
Not sure about the steel sources, but I know I have seen one woodworker at our turning club who bought and used larger Allen keys that he shaped and ground to make such small hollowing tools..just an idea..put them into small handles and the worked great!
>Yea, I have a few of those Jim....thanks....I'm looking for something a little more substantial though. I've only used small realy small allen wrenches....maybe using some bigger ones might do in a pinch? I need to make 5 tools for a miniature hollowing class I'm teaching at WC in two weeks. Should be interesting.
>I purchase drill rod from McMaster Carr. Either oil or water hardened. I did not notice much difference between the two for small items. Geenerally, I heat with a torch to take out the temper, shape, and then temper again. See WC articles for instructions.
You can try 32435A51 tool bits. 5/32 round - $2.59.ea in catalog.
>I bought some 5/32 drill rod at a local Hardware and made a set of small tools from it. Have not used them much. I made a straight one, an angled one, and one with a curved offset. Did not do much with hardening, I think I heated them with a torch and held them hot for a few seconds and quenched them. Not at all sure, but they do so little "work" hollowing small pieces they seem to do fine.
everyone has differnt opinions. I too started by making my hollowing tools from Harbor Freight Allen wrenches. They worked good.
I recently purchased tool steel from mscdirect.com
I buy m2-hss in 6" lenghts. 1/4" square. They cost about $6.50 apiece.
You do not have to braze on tips and if you break one it just makes good stock for future projects.
I bend these with mapp gas. It gets hot enough to bend but not hot enough to remove the temper. I make a set of 3. one is straght, one bent 90 derees and one shaped like a question mark.
I put in the second bend so that the cutting tip is close to aligned with the shaft of the tool. Neither creates any torque when using.
>Jenn, I too have bought from MCS, both drill rod and HSS. Wouldn't round stock be better than square. It has a smaller cross section and if the tool touches the neck of the vessel the round would be more likely to just rub whereas the sharp corner of the square stock could bite into the wood. as they say my.02 worth. Dennis from Bloomington many many years ago now warm in Florida
>Don't forget that most drill bits are HSS. A short piece of the stem of an old drill into an end-drilled larger piece of cold rolled would work well for petite turning.
HSS and Carbon Steel are determinable at a bench grinder. HSS has small fine streamers and fine sparks. Carbon Steel will have small streamers with fairly large exploding sparks at the end of streamer travel.
As for you guys who buy "keyways" at the local hardware, the "keyway" is the groove in the shaft & pulley bore that the "key" fits into.
>...instead of 1/4. The 1/4 cutter with take a pretty big bite in a small piece of wood like a Christmas ornament ball. If that is how you are going to use them.
>Jennifer I've missed all this excitement. I've a been shooting ceramic artwork all day. I generally make my smaller hollowing tools out of 1/4" drill rod and just heat treat the end and shape it. I like this as good as using HSS 3/16" cutters silver soldered onto the end. It's just easier and faster to make I don't see any real difference in life of the edge. I hollow 3 to 5 chrismas balls before I touch it up. Actually I use 2 cutters to hollow the balls, one is curved. I touch up the straight one after 3 to 5. The bent one that I use less often will last through about 10.
I get the drill rod from www.travers.com. They run it on sale every now and then and it's really inexpensive. I also use 5/16" drill rod for slightly deeper ornaments. I just get less chatter with those. Travers also carries the 3/16" hss cutters.
I like drill rod, especially for the curved cutter because if I decide that the curve isn't right or the tip is getting too short I just stop, heat it, straighten it and rebend it, then reheat treat it. it takes me all of a couple minutes to do this. On 1/4" stock I can do this with a propane torch. With the HSS tip I have to dig out the silver solderflux and my MAPP gas torch and go through all of that.
>I picked up some picks from Northern Tool. They are about 1/16" and are in 4 different shapes. I just ground them the way I wanted and they work OK on the two small pieces I have used them on. I did a 7/8" X 1/2" and a pot that's 3/4" X 1 1/8". I am going to cut the plastic handles off and make some longer wooden ones. They work good for the price. They were $5 for the four.
>Thanks everybody....I've got my shopping list and a couple of local places to check out. Still having a hard time finding cold rolled bar stock? I may also try the round bars too. I have made a couple and rarely use mine, but the person who I gave one to says it's hard to keep from rolling over while hollowing. I'd like to try to bend some drill rod too make some. I do use Drill rod for that correct?
Thanks again...I hope this is the last time I ask about making these!
Here is a great site. Tho you aren't making a hook tool Alan gives some great tips on how and what to use. Saw him make one of these. I hear Enco is the place to purchase tool stock.
>Yes, you want drill rod for bent tools. I find W1 easiest to use, don't need to keep quenching oil around. I also fine it better to make the handles from square stock with the edges rounded over. It's easier to keep the tool orented with them.
