We value your privacy.
>Use a chain saw to round a turning blank? Several members have posted that they round turning blanks with the chain saw, and I am wondering what arrangement they have for holding the blank while making the cuts. My band saw has been sold and I would like to round some blanks but am a little hesitant to do it with my current setup. A picture or two would help. Thanks.
>Don my setup is gone now that I have a good bandsaw but what I did was set up a big log as a platform. I attached a rope to the back side and ran it over the blank. I put a loop in the other side and stood on this loop to hold the blank. I placed a wooden circle on top with a nail through the center as my guide (the rope ran over the top of this). Then I would just cut close to the circle of wood with my chainsaw. When I first started turning green wood I cut the blanks with a bow saw and chopped away corners with a hatchet.
>Lay the log on it's side and rip cut it in half. Put the flat side on the end of another log or saw buck and cut the corners off at a 45. It will not be round but will be close enough. If it is a large log you can 45 the 45's to get it round.
>Don, I learned this method from another club member. Take a log about 2-3ft long and stand it up on end. Using your chainsaw, cut a V-notch into the top of the log. This creates a cradle which you can place your blank in. The rounded portion fits into the V-notch, and the flat portion is facing up, so that if you've drawn a circle on the blank, you can sort of follow your drawing.
Your chainsaw will eventually cut up the V-notch, and you'll need to start over, but it beats the heck out of bending over your back cutting your blank on the ground and digging your chainsaw into the ground.
The assumption is that you have already 1/2 the log (which I do by just letting it lean against the upright.
After the 1/2 is made, place the flat side against the upright and wedge under the curved section. Doesn't take much, and sometimes I skip this and just cut another flat section parallel to the upright. Once I have two flat, parallel sides, I draw a circle on the "top", and trim a rough circle with the chainsaw. By a rough circle, I mean cut the corners off to form an octagon, then cut the points off of the octagon to approximate a circle. All of these cuts are done with the blank laying flat, circle drawn on the top.
By doing this, I'm usually able to rough out on the lathe at 700rpm without chasing the lathe around the shop.
>Don, I do as Steve and rip the log while laying in the trough of the sawbuck. I then cut the corners of the halves after attaching a cardboard circle with a nail in the center. How round I make it depends on how large it is for balance. Attached is mine on the top (the sides and the botttom are replaceable) and Dave Peebles on the bottom.
>John, From your description, I'm glad you got a band saw. I visualize that log rolling away with you in hot pursuit, your foot through the loop, being dragged along trying to hold the marauding chainsaw at bay. Hope you were doing it on level ground at least. Sounds dangerous at best.
I have tried to figure out some sort of setup to allow the rounding of blanks with a chain saw. I have done most of mine by just chocking two logs together side by side and laying the blank in the vee between the two. They get chewed up, but, Hey, they grow on trees.
I was actually considering something like a circle gig for a bandsaw. Would it work to have a series of holes in the bench and put a center hole in the blank and then have a couple of verticals like Steve's to run the saw beside? The you could chock the blank, saw it, turn it forty five and saw it again and again until it was and octagon or whatever. I was also wondering about some sort of pivot for the saw, such a a bolt through a hole in the end of the bar, but that is beginning to would dangerous. A sort of cross between and circle gig and a chop saw. Any merit in any of this?
>Barry I cut a lot of blanks that way with narry a problem. I think the saw would cut the rope pretty easily. I used to just put my foot on top of the blank and cut. As you can imagine the rope is one heck of a lot safer than that. I tried using a sort of lever made out of wood but the blank thickness varied too much and this just didn't work very well.
>Thanks, everyone. I guess my major concern is that since I have a Jet mini the blanks I need are not that big. I am always afraid that the saw will somehow pull the blank toward me as I am cutting. The rope idea or perhaps a band clamp may be the best way to hold the blank solidly as I cut.
>Don Use the portion of the bar that lets the body of the saw touch the blank. My saw has a couple of teeth that touch the wood. This keeps the wood from being pulled into the saw because the saw is already touching the wood. It also keeps the wood from rotating.
>John, I usually do saw that way, but to get all the way through sometimes the shape wan't quite allow that. Of course part of the problem is that I have lost a lot of confidence as I have aged.(G)
