Say goodbye to Ash...
Devon Palmer
>My father reported the other day, that the Indiana DNR has been clear cutting large groves of Ash trees as a means of combatting the Emerald Ash Borer. They cut'em down, shove them in a pile, and burn them (I would assume they are infected, but, it wouldn't suprise me if it was pre-emptive). Supposedly, you are allowed to mill them onsite if you cut them to 1 inch of thickness as the wood dries out fast enough to prevent the grubs from reaching maturity.
I've also seen postings at interstate rest stops that warn against transporting of wood across state lines and it specifically mentions the emerald Ash borer.
It saddens me as Ash is one of my favorite woods for single turned bowls. I was lucky enough to turn 4 truckloads of it last summer and fall, but, I'm left wondering if there will be hardly any left in 2-5 years.
Anyone have any more insights?
- Devo
Re: Say goodbye to Ash...
>Have a friend in Wisconsin that told me they were cutting a swath across the state about five miles wide to combat the Emerald Ash Borer. His Idea was that they thought insects could not cross such a wide barrier without help. Lets hope it works or they get something that does.
Rick in Colgate, Wi
>Its my understanding that Michigan has a huge problem as well with the emerald borers.
Jennifer@Indy.USA
>Yup, it's been in the news here in Indy. We'rr seeing it here in Central Indiana now. A crying shame.
jared
>remove 1 for email
There are a lot of different species of Ash. Is it specific to one ore does it affect all of them. I live in western iowa and most windbreaks on farms [I live on one] are what is called Green Ash. This country would look really bare if there were no ash trees. Jared
Re: Say goodbye to Ash... - - Michigan update
Pete in Holland, MI
>Michigan does have a problem with the borer. Several counties have quarantines for moving any kind of wood. Fire wood has apparently been the biggest source of movement for the borer. The Mackinac Bridge, that connects the upper & lower penninsulas of Michigan, has banned ALL firewood moving northward in an attempte to keep it out of the UP (Upper Penninsula for you out of staters).
Matt Berry
>Green ash is just as susceptible as white ash. Emerald ash borer has been a problem in michigan for years now. It's sad to say but they keep moving the quarintine zones, removing trees and such, but it isn't slowing them down at all. The problem is also in canada. It problem won't be too long before EAB destroys most of the ash trees.
Chris K in MD
>THis is the first I have heard of this. Its really a downer. I made Four ASH bowls recently and gave them all away. Thwy were really pretty. Where can we read more about this?
Some Canadian Info *LINK*
Jim Shaver - Oakville, Ontario
>Hi,
I did a quick Google search on this for some Canadian info (tons of info and maps).
I have seen the "ash free zone" cut down located between Windsor and Chatham, ranging north from Lake Erie to Lake St Claire in a corridor to try and control the spread up from the Windsor region into South Central Ontario. It seems that the spread is still on...very sad indeed.
take care,
Jim
Emerald Ash Bore in SW Ont.
Re: Some Canadian Info
Chris K in MD
>Thanks Jim,
I just found this as well via google.
http://www.indystar.com/apps/pbcs.dll/article?AID=/20060121/NEWS01/601210439/1006
TD has discussed this issue
Stuart Johnson
>TD has talked about this type of issue several times. What good does it do to have an Ash free zone when we ship blanks back and forth? Do woodturners help spread this type of pest or is there no significant impact?
has been confirmed here, too
Mike Schwing from Md.
>Emerald Ash Borer in Maryland
On Thursday, Aug. 28, 2003 a Maryland Department of Agriculture (MDA) inspector found emerald ash borer-infested ash trees at a single Prince George�s County nursery. The U.S. Department of Agriculture (USDA) Systematic Entomology Laboratory in Beltsville, MD confirmed the identification of the emerald ash borer. Emerald ash borer (EAB) is a serious pest of quarantine significance. To date, the emerald ash borer has only been detected in the U.S. in 13 counties in Michigan (2002), five counties in Ohio (February 2003), one county in Maryland (August 2003), and two counties in Indiana (April 2004). The Maryland Department of Agriculture issued a Quarantine Order on March 17, 2004.
I would hate to think it was us, but....
T Daniel
>We are the worst. Other woodworkers would ship kiln dried lumber but we turners just throw a piece in a box, bugs and all, and ship it coast to coast. Shame on us!
TD
Kissing our Ash Goodbye
>I hear it is in the northern part of our state. Irony that the American Elm is coming back and now this.
Tommy
Re: Kissing our Ash Goodbye
Ed Karch
>My group (fairfax reLeaf) has planted several hundred thousand ash mostly green in the last ten years here in Northern VA. Luckily we also planted many other species as well but ash is still one of our standbys. I just turned some American Chestnut from old bug chewed barn beams. That was a real loss.
Turners not the worst offenders
Bob Hackett(Mainely,Bob)
>If the pallets I get from our dump are any indication(and I believe they are) then the pallets most things are shipped on are a far worse threat than we ever could be.I`ve taken apart green wood pallets of ambrosia maple and sycamore where you can still smell the sap.Some of the larger cross pieces are full of borer holes etc.I know 2 of the local pallet mills up here don`t fumigate any of the outgoing stock so I can`t imagine anybody else is.
Mainely,Bob
Re: I would hate to think it was us, but....
Gary Evans Tallassee, TN
>I have to disagree, Terry.
The Emerald Ash Borer lives under the bark. It also loosens the bark. You would know if your wood was infected. I can't believe that moving a little turning wood around the country is going to lead to an outbreak of any kind of insect or disease. Sometimes it's not a bad idea to cry wolf, but I don't think this is one of those times.
Gary
Re: Say goodbye to Ash... *LINK*
Ken Grunke from SW WI
>There's been a long discussion on EAB at the Forestry Forum, based in Michigan, with a lot of forestry profesionals as members along with an occasional nuthead.
EAB Discussion on the Forestry Forum
Seeing this thread prompted me to make some additions to our AAW chapter website's links page, pointing to informative sites:
CRW Links page
