Another photo question
Gary Evans Tallassee, TN
>As some of you may have read in my post about Carole's beautiful work, my digital camera took a dive a few weeks ago and now seems to have a permanent limp. Looks like I'm in the market for a new camera whether I want to be or not.
What are the deals right now on Digital cameras? I'm thinking at least 5 MP. I've looked a little at the digital camera bodies since my wife has a nice selection of lens for her Minolta SLR. It would also be nice to find one that uses the same memory cards as my Olympus D-510, since I already have a couple of extras.
I probably need some help with the language here. Do all lenses use the same mounts or do I need to find out exactly what kind of mount these lenses use? Her camera is probably 15+ years old.
If I have a good show in AZ, I'm thinking I may be able to spend $300-400 for the new camera. I would appreciate any and all comments.
Thanks,
Gary
Re: Another photo question
Barry Turner
>No such luck. I think you will find digital SLR's of every brand, each with proprietary lens mounts. I doubt you will be able to find a digital SLR body for less than $700 or $800 either. There are some very good digtal cameras in the $400 to $500 range, though not SLR's. I have an Olympus C-5060WZ, 5.1 MP, which I like very much. It takes some very good pictures. Good luck in your search.
JKJ in East TN
>Gary,
There are many different camera mounts, and worse than that, there are different systems for metering within the same company so even if a lens connects, it may not be convenient to use on another body.
If you are not aware of it, there is one other big "gotcha" when using SLR lenses for 35mm film camera on a digital camera. The typical digital sensor is much smaller than the 35mm film frame. This means that every SLR lens will act like a telephoto when used on that digital camera. This is great if you are doing wildlife photography but a real pain for indoor work where you really need a wide angle lens! The trend is towards larger digital sensors on the better cameras, but the last I checked the price was still very high.
Another factor to consider for digital cameras with interchangable lenses: since the "film" is never advanced, tiny specks of dust can enter the camera during a lens change and end up on the sensor chip. These specks make dark spots easily visible in lighter areas such as sky. It is difficult or impossible to clean the sensor yourself and often requires sending the camera in for service. Where I work, some of the professional cameras don't get cleaned often (or ever) and I'm stuck with touching up the spots on photos. One photographer had several spots in the same places on every picture for at least three years (until he got a new camera!)
One alternative to interchangable lenses is a good zoom lens. I personally use an older Olympus E-10 with a non-interchangable zoom lens. It has all the manual controls of a good film SLR including a real focusing ring! Sorry, I haven't kept up with the latest out there except to see prices are still dropping. (I think my E-10 was about $1800)
Re: Another photo question *LINK*
>Gary Your minolta lenses won't fit any digital. JKJ is right about interchangeable lenses being a problem. I usually suggest fixed lens cameras unless you need the versatility that a professional photographer needs. Check out DP reviews on the link below. You can put it price or megapixels and then compare the models. You should be able to find one that takes your cards.
http://www.dpreview.com/
Ric Taylor
Ric Taylor
>Gary,
I have the Canon Digital Rebel, and one of the main reasons I selected that camera is because it accepts all of my old lenses from my ancient Canon EOS 650 film camera. Everything works great. I have no problems at all, and no trouble with dust spots. Dust spots can happen on any camera, film or digital, that have removable lenses. Care is needed to keep the inside of the body clean.
I don't know if any of your old Minolta lenses will work on any of the Minolta digitals, you should take them to a camera shop and ask that question. I am pretty sure, however, that they will not work with any other brand of digital camera.
Good luck,
Ric
>Dust on the sensor is a fact of life for digitals with removeable lenses. We fight that problem at work and clean the sensors a lot. I have tried very hard to keep my Personal camera clean but after a year there are spots. You just learn to retouch quicker. They have cameras with such long range zooms that you don't need interchangeable lenses unless you need very wide angle or very fast lenses.
JKJ in East TN
With film, you may get a dust spot on one negative, then the film advances. With digital, you get the same spot on every picture.
Bob Elliott
>Gary,
I hate to have to break the news to you, but the card on my Olympus D-510 Zoom is obsolete! Olympus does not use that card on the newer models, and I don't think anyone else does either! The largest one you will find is 128 mb. So I'd say forget about that idea!
Do yourself a favor and call Olympus 888-553-4448 and select option 4 (trade up info). Then select option 5 which is the service department. They will take your camera info, invite you to send them your old camera and old Olympus branded Smart Media Card(s) and they will evaluate your camera and get back with you with a trade in value on certain Olympus models.
When I checked about a month ago, the models they offered were the SP 310, SP 350 and the Stylus 800. Also included in the trade in / purchase deal is a two year extended warrantee for a total of 3 years! This is something they do not advertise...but now you know! You can trade in your old technology!
List features you need, then....
JamieDonaldson
>...go shopping at a real camera store where you can play with the real cameras. Few average shooters need more than 5MP, and there is a wide selection of very useful cameras for less than $500 these days.
Pascal Oudet
>John, I'm sorry, but the Minolta SLR lens fit on the digital version.
I have a Dynax 5d (I believe the name in the US is Maxxun 5D), and I can use my old lenses (28-105 and 70-300) on it. actually I was more inclined to buy the Canon EOS350D, but finally chose the Minolta because I could reuse my "old" lenses.
there is a 1.5 conversion factor (the first one becomes the equivalent of 42-150, and the other 100-450), but they do work perfectly.
last point: I just heard Konica/Minolta is stopping all camera activities, so it might not be the right brand to invest in these days (though I've also read that Sony will take over the products).
Pascal
