We value your privacy.
>I need a small lathe for craft shows and small stuff... Before I finish making up my mind, I thought I'd ask how slow the VS mini will go. The brochures all mention 500 rpm - something like 3000, but can it go slower, even with very little torque ?
I would prefer to sand slowly, so full-torque low RPM would be nice, but I could use low torque slow speed for applying finishes.
>Nope - 500 is the low end. That is my main complaint about Jet coming out with that lathe. Same speed range as the original. All the VS motor/controller does is save you from having to change pulleys. That was the genesis of me putting a DC VS motor on mine.
>Jet VS Mini slowest speed is 500 rpm. This is slow enough for sanding, but is the top end of the speed for thread chasing. I have a Nova Mercury with 1/2 hp motor. It is also a variable speed and the control will take the speed to zero. It is a little lighter than the Jet Mini, turns nealy a 10-inch diameter and is great for travel. I haven't seen one in the stores for a long time, thus don't know if they are still available. Sure glad I got mine.
>I have a belt-drive Jet Mini. Normally, I just pick an intermediate speed and turn away. I use the lowest speed for bowls up to 9+", but for most anything else, one of the middle to high speeds is fine. I think the VS model is over-rated and not worth the added price.
I actually prefer the General "Maxi" lathe, which is much heavier, and in my humble opinion, better made, as well. It is a manual belt-change lathe, so I thought if the VS mini went slower than 500 RPM, I might reconsider and get a Jet for finish application. If 500 is the low speed, I'll stick with the General.
I do think that for delicate segmented work like Mark does, the VS is a real advantage in tuning out chatter; for most of my needs, it isn't needed.
>Since I only turn pens I have always wondered if anyone has turned a "pulley to go on the threaded part of the drive shaft.the largest dia might be a little over 9 ".Lest's call it 10 to make the math easier.
Using a "vacuum cleaner belt" hook ip an auxillary motor behind the lathe.
If the second motor is running at 1750 with a 1" pulley then the lathe speed would be about 175 rpms+-.(less than 1/2 of the lowest speed)
Of vourse there would be a need to disengage the lathes original drive belt.
Just wondering.
I realize a VS dc conversion would be better, but the second AC motor is cheaper.
