Bill Grumbine
Bill Grumbine
Bill Grumbine
Mark Kauder, Phenix City, AL
>Bill,
I know you told me before, but my memory ain't as good as it was. What guage copper tubing did you suggest for a compressed air system?
I have some "L" in the shop, and it looks pretty stout.
I am going to use a regular rubber hose to go from the Compressor, through the wall into the shop and then go up over head to make a run to the end of the shop w/ a couple of outlest along the way.
Mark
Re: Bill Grumbine
Re: Bill Grumbine
George Van in WI
>Just a thought about rubber hoses. It is best to shut off power to the compressor or air line when you leave the shop. If you do not you may hear it running after the hose springs a leak when you go for your snowshoes in the morning. Luckily I think mine will be ok after I change out the oil. The shop smelled like burnt oil for 5 days.
Re: Bill Grumbine
Re: Bill Grumbine
Bill Grumbine (Kutztown PA)
>Hi Mark
Schedule L is what I used, and it has been working well for the past two years - well, two years in March. I have mine hooked to a rubber hose as you describe, and I can attest to remembering to turn the compressor off when not in the shop as George mentions. I have not had trouble with my hose, but every now and then the pressure relief valve blows (at the low end of the pressure cycle) and the thing will run until someone shuts it off. I hate coming up to the shop in the morning and hearing the compressor running, so I make it a point to shut it off.
Bill
Re: Bill Grumbine
Re: Bill Grumbine
>Thanks Guys. I currently have my DC on the same circuit as the lights so that I do not shut down for the night with it running. Unfortunately, I don't know that the 30amp circuit can stand the addtional load of the AC as well. Since the DC and AC are in a different room from the shop, it is a pain to shut off the AC. I will figure it out.
Thanks again.
Mark
Re: Bill Grumbine
Wrong!!
>I am wrong with what I wrote. The DC is the same 30amp Circuit as the waist level outlets, that I intend for light duty power tool, but it has its own switch next to the exit door, and the switch has a light in it to tell me when it is on. That way when I shut off the lights, I will be warned when the DC is on. The lights are on a 20amp Circuit, and the RADIO is plugged into that circuit so I don't leave it on. My AC is on the same circuit as the floor level outlets - my TS is plugged into that - rational being that I will not be using the TS and something that needs the AC, but would be using the TS and DC at the same time.
For what it is worth, the Air Conditioner and the IR heater are on a dedicated 20amp circuit.
Not that any of that matters - just wanted to correct what I first wrote.
(seemingly forgetful )Mark
