Wheel balancing system
Dawn Adams
>Does anyone have the Oneway grinding wheel balancing system? My grinding wheel seems a little unbalanced and I am wondering how big of a difference this will make in my sharpening. Any advice is appreciated!
Dawn Adams
Re: Wheel balancing system
Jim Shaver - Oakville, Ontario
>Hi ,
I have the system and love it!
First I balanced the wheel and put it back on the grinder, then I trued it up becasue of the abuse it took while not balanced. Then I took the wheel off the grinder and rebalanced it again, put it back on teh grinder and zoom, it was as smooth as glass.
I love how smooth it runs and how easy it was to balance, hey, my tools even stopped bouncing off the wheel!!... Just my experience.
take care,
Jim
Better yet, is there cheaper alternative?
Basil Biberdorf
>Is it just me or does this Oneway stuff always seem horrendously overpriced? Both the balancing system and the Wolverine sharpening system seem to cost far more than they should, considering what they are and the materials and parts used to make them.
The $50+ nickel-and-diming sure adds up over time. Being a pastor on a limited budget, perhaps I'm more sensitive to this than other people, though.
Re: Better yet, is there cheaper alternative?
>Basil There are many of us on a limited budget. I don't own the balancers yet because of the price. I carefully shimmed my wheels until they ran true. Probably took longer but it didn't make sense to me to pay more for a balancing system than my grinder cost.
Alignment and Balance
>Hi John,
What you did was really good for alignment, probably the biggest issue with wheels on grnders I think.
But the same can be said for a wheel on a car I believe, it can be aligned, but balance also aids greatly in smooth running, so for me the One Way corrected both on my wheels and grinder ..
take care,
Jim
Re: Alignment and Balance
>I would agree Jim. The wheel itself can actually be out of balance without being out of round. it's simply a monetary decision for me. I got by for so many years with a cheap sears grinder and gray wheel that stepping up to a decent grinder and white wheels that run pretty darn smooth(not perfect) is a big step in the right direction. Knowing the way I do thing it won't be very many years before I do buy the balancers.
Cheaper?
T Daniel
>We sometimes forget how small this market really is. Items for us woodturners are made in small quanities in small shops. You just cannot get the mass quanities to bring cost down to Walmart prices.
Most of the cheap grinders use stamped "washers" to hold the wheels on the shaft. The original plates (washers) on the cheap grinders are very thin and do not hold the wheel 90 degrees to the shaft, therefore wobble is likely. The One-way balancing kit includes plates to hold the wheel 90 degrees to the shaft. Most cheap grinders are fixed just by adding these plates if the wheels are new. Once the grinder has been used however, the wheels are out of balance and must be trued and balanced as Jim has said. You can spend a few more bucks and get a Baldor or an old style Delta and you will not need the One-way kit. Just add the cost of the One-way kit to the price of the cheaper grinders and compare that to an 1800 rpm Delta or the Baldor. It really doesn't cost a lot more to get a good grinder to start with and it will likely never have to be replaced.
Re: Cheaper?
Basil Biberdorf
>I understand what you're saying here, but the $57.50 price tag plus another $10 - $15 to ship it to me simply seems too high. I'm using the Woodcraft slow speed grinder. While it's no Baldor, I don't think it's fair to suggest I'm using a $35 Harbor Freight special.
I cannot speak to how much Oneway determines its costs to be in making their products, so I won't try. But $75 (final cost) for the wheel balancing kit is a "barrier to entry" for me.
Re: Cheaper?
>Hi,
Well I can tell you the quality of the OneWay product is really good...given what you pay for a grinding wheel and the rate of consumtion of a wheel that is poorly aligned and balanced I think it would pay for itself in wheels alone within a few wheels, never mind safety.
Cheap grinders....don't know....I bought my slow speed 8" General International a few years ago for about $100 us......the balancer plus decent wheels and the One Way products are cheap compared to how much I have spent on turning tools I do not use. I never regret buying quality that makes a difference...I have a drawer full of turning tools I don't use, now that is pure waste.
Take care,
Jim
Re: Cheaper?
>I need 2, one for each wheel so that doubles the cost which is why I haven't done it yet. I do think it is an important option. There's nothing more frustrating than trying grind a good edge when the tool is bouncing off the wheel.
Re: Cheaper?
georgetroy
>I'm with Terry on this. The $200 Delta 90 lb. grinder is nice. It just sets there and purrs. I don't think this model is made anymore. GT
Re: Cheaper?
Sean Troy
>They come with two. One for left and one for right wheels.
only one needed
T Daniel
>John, the balancing kit has hubs for both wheels. One kit does it all for one grinder. The kit has a right hand and a left hand hub assembly.
Re: Cheaper?
Ric Taylor
>I can help you clean out that drawer.....
Ric
Re: only one needed
>Thanks Terry I didn't realize that and obviously that makes a big difference.
Re: Cheaper?
Paul in Phoenix, AZ
>Try Lee Valley Tools, they seem to have the balancing system about ten dollars cheaper than Oneway. Or at least they used to. It's unbelievable what a difference it makes for a cheap grinder.
Quit looking at the price and think about how much of a difference it will make grinding your tools. And then the smoother cuts you can make. It was definitely worth every penny or me.
My 2cents.
~Paul
Re: Cheaper?
Basil Biberdorf
>Just a matter of spending money that I don't have.
If money were no object, I'd have a Powermatic 3520 instead of the Jet mini I have.
albertabob
>Basil, I have been grinding stuff for many years.
I doubt that I have ever had a balanced wheelin my entire lifetime.
We used to buy a dressing stone and rub it along the cutting edge of the stone to true it up.
That's not good enough for a lot of hobbiests now cause they have time to tinker around with gadgets. More power to them.
Of late, I have been dressing my stones with a diamond dresser and or a star wheel and that seems to work just fine for me.
If I buy a wheel that is not cored centrically- "wobblers" (I got some from Jet like this ) or is not balanced to rest on a pencil, I just take it back.
Everything else I can handle with a dresser.
Don't be too hard on yourself or your wallet.
It's supposed to be fun , not expensive.
Bob
ben d.
>Another go on wheels that wobble. I just purchased a slow speed grinder from woodcraft that the wheels wobbled and they sent me another one that did the same thing, so this is what I did.
Removed the wheels and shields and you are correct they use stamped washers and they are not true. I left the inside washer on made a spacer to slip up on the shaft, secured with the nut and turned the grinder on and the washer wobbled. I ancored the grinder down got out my little 4 in. hand grinder made me a bracket to set it in, turned the grinder on and with the 4 in" running also moved it in to the washer and took off the high spot until it did not wobble ( trued up )and did the same for the outside washer on both sides. Now there is not a noticable wobble in the rocks, trued up with a wheel cutter and it works fine.
No doubt if you had a machine shop buddy he could turn some and all would go away. Another way to fix something.
Dinyar Chavda
>Try this link:
http://www.homemetalshopclub.org/news/sep04/sep04.html.
It has the magical word :"Free"! (other than the cost of some parts that you may have lying around.
