Chasing Cracks
Chasing Cracks
Chasing Cracks
Tomm
>I noticed a small crack on the outside of a rough turned bowl. It was only visible from the outside and did not appear to go very deep. I thought that I might be able to cut through the crack and remove it when I finished the bowl. When I turned the bowl, I found that the crack went a little deeper than I thought and I could not save the bowl. Are rough turned bowls worth turning once they start to check? Are the cracks sometimes small enough to turn past them? Thanks for your comments.
Re: Chasing Cracks
Re: Chasing Cracks
Dale Cook
>Hi Tomm, if you still have the bowl you could try this method of repairing the crack. I've had fairly good luck fixing small cracks by soaking a piece of paper towel with water and cover the cover the crack by at least an inch or so around it. I check this twice a day for several days, re-wetting the paper until the crack is closed completly then I supper glue the wetted area. I've saved several pieces this way. Good luck.
Re: Chasing Cracks
Re: Chasing Cracks
GaryG in MD
>Dale is right. If you catch the cracks quickly, CA (super glue) can often save the blank. Every piece of wood is different, but if the cracks are stopped quickly with CA, they will often tighten up and stay closed as the blank dries and shrinks. ...Gary
