We value your privacy.
>Wondered if anyone had a link to a good website on using stones to hone tools, either in addition or instead of just using the grinder. I am wanting to give it a shot, if nothing else to get a comparison and see why some people are saying it's the way to go.
>HI Larry, I hone my spindle tools but not my bowl gouges (usually). The difference is dramatic...especially with the skew chisel. I use old fashioned bench stones, since I feel I have better control. I hollow grind my edges, then keep both the inner and outer edges of the grind in contact with the stone, rolling the gouges while maintaining to same angle. Another good method is wet or dry paper on a sheet of glass...works well.
For tough bowl forms, tearout, etc. I'll hone a bowl gouge. Just a bit of practice and you'll be a pro.
>Larry I use the cheap plastic diamond hones. I hone my skew religeously but seldom hone anything else unless I'm having tearout problems. I also have an 8000 grit slipstone that I will occasionally use on the inside of the flute. I use it when I'm having trouble with the above mentioned tearout on problem woods.
>I also use the folding diamond hones and just pin the tool with my off hand to either the toolrest or the tailstock if the rest is too close and move the hone over the stationary tool.
I`ve been known to hone just about anything but I think I`m the exception.I find I can hone a tool 2 or 3 times to refresh an edge before having to go to the grinder again.
>I hone all my tools except for the scrapers. I use a Tormek, which has a two leather wheels. One is flat and the other is contoured for the flute of a gouge. I start by sharpening on the stone (1000 grit) and then honing it with the leather (400 grit). The next time I just go to the leather hone, and only go to the stone every other time. Seems to work for me, and my skews are razor sharp.
I have read some articles about paper wheels and various grits of compounds. I plan on trying these later on, but for now the leather works good enough.
>>..Wondered if anyone had a link to a good website on
Larry,
I don't have a web reference, but I hone most tools. I sharpen with a grinder (or more often, a Tormek), then hone many times between sharpenings.
I mostly use the very fine plastic-handled diamond hones held in my right hand with my forefinger pressed right behind the diamond surface. I place the hone surface in contact with both the edge and heal of the tool then hone across a skew or around with the curve of a gouge. It is important to keep the hone in firm contact with the two edges to prevent deforming the cutting edge. I've seen people hone this way with a credit-card-sized diamond hone and I've done that as well, but I find it more difficult to control. Maybe I just need more practice.
A couple of strokes will leave a small flat on the cutting edge and another on the heal of the grind. After a few honings, the flats get large and the honing starts to take too much time since more metal must be removed, so it's back to the grinder.
I sometimes use a rounded hone on the inside of a curved gouge, but you have to be careful not to round over the edge. I haven't had much luck with larger flat stones such as you would use on a plane iron.
