Another Lathe question
Bob Fawcett
>I thought I had decided on a Jet Mini. My local dealer doesn't have the mini, but can order it.
He does have a Delta 14 x 40 iron bed (46-715). Its on sale for $609 and comes with a free starter set of Delta turning tools (8 tools).
The headstock is threaded 1" 8 and can swivel to the front or other end.
Is there any reason not to get the Delta?
Does anyone have experience with it?
Re: Another Lathe question
>Don't want to speak out of turn here, but that has never stopped me before. At our last turning club meeting at the local Woodcraft store, there was a discussion between the store owner and one of our members. I believe they were discussing that same lathe and the owner said that Delta had confided that there were some lathes out there that had problems. The head would not lock securely in place and tended to float around in use. Offered to help the club member get Delta to fix his or would swap the head off the one he had in stock. Again, I am not sure exactly which lathe it was, and it seems there were some (batch or batches) that had the problem and some that did not, but you should check further. The store owner gave the lathes without the problem good marks.
Bob Fawcett
>Short of trying the machine, is there a way to check that?
Thanks for the info. One reason I'd like to buy local is that I think these people will help me with problems of this type.
I also see from another thread I should look at the alignment between the headstock and tailstock.
>Bob, I really don't know, I would ask the dealer. I would try locking the head and giving it a good shake or twist, but I don't know if that tells you much. Lock it in place and put the centers in and bring the tail stock up. The points should line up accurately.
My Nova has a pivoting head and the other day i realized it was making and odd noise and finally notice I was turning without the head stock being tightened down. It has an indexing pin, but you tighten the headstock down to the bed also. At least I should have.
I could ask the owner of the Woodcraft store for more details, but I really wasn't paying that much attention, because I don't own that lathe and was not planning to buy one. May be a non issue, They may have addressed it, but I believe he said he was waiting to order more until he was sure.
>I have one sitting in my basement. I also have a Jet 1642 EVS. The Delta is a good spindle lathe. It is somewhat underpowered (3/4 hp). I wouldn't put a heavy chuck on it. The legs and undercarriage are stamped metal and sort of flimsy. Build your own if you want stability. If you want one, I can let you have one really cheap - especially if you are within driving distance of Atlanta.
Bob Fawcett
>I am in Savannah. Email me. remove the nospam from my address.
>Bob I sold that very lathe and bought an old lathe thinking I would rebuild it and have a better lathe. I was unhappy with the vibration in that lathe. As it turned out rebuilding the new lathe took more time and money than I had so I bought a mini lathe to tide me over. It ran so much smoother than the delta that my turning skills improve almost overnight. I tell people with all honesty that I would buy the Jet mini before the Delta 46-715 any day. If you want a bigger lathe go with a different model.
Bob Fawcett
>Thanks John
After much looking and reading and asking I ordered the Jet Mini tonight.
Too many people say the same things.
>Good choice. Great little lathe. VS or belt?
Bob Fawcett
>Belt. I thought long and hard about the VS, but I see it still has 3 steps on the pulley. Keep it simple.
