Jet vs Rikon mini lathe
Trevor
>I am looking to get started in this new hobbie, and I was wondering which is a better lathe, the Jet that can turn 10" x 14" or Rikon that can turn 12" x 16"?
-Trevor
Trevor
-Trevor
Re: Jet vs Rikon mini lathe
>Trevor We just went through this down below. See if you can find it. I think it basically went with the Jet being a proven known good product and the Rikon being unknow. Might be a good lathe and I hope it is but they just haven't been out long enough to know. If you go the Rikon way make sure you buy it from a reputable dealer just in case.
Chris K in MD
>I would go with the Rikon but only from Woodcraft for the reason that John mentioned. It is an unkown but thier bandsaws are getting GREAT reviews. THe rikon dies have alot of features going for it and thats why Id give it a try, woodcraft has a one year return policy.
If I was going to buy one I would give it a try
Good luck
Chris
eaglesc
>I own both.
Non VS (Not worth the extra money for me)
I was considering a VS Jet until I saw the Rikon.
Since I only turn pens the larger capacity didn't mean anything.
What I did like was the indexing head on the Rikon and the ease of speed changing for a non VS unit.
The Rikon has issues but I have not contacted WC or Rikon.
I still would consider either one.
JKJ in East TN
>Our local Woodcraft switched from pushing Jets to Rikons. I asked if it was a financial reason and the owner said he saw increasing problems dealing with Jet while Rikon has been far more responsive.
Re: Check the alignment of the centers.
Al Crandall (NE of Indy)
>I looked at the Rikon at our Woodcraft and noticed that the centers fell far short of aligning. This isn't a problem if you are turning items between centers exclusively. It will become hugely apparent if you fixture a blank in the headstock and drill a deep hole into it using a drill chuck in the tailstock. Make the alignment check with the tailstock spindle at both ends of its travel. The wimpy see-through plastic drive belt concerns me also, but it may prove to be a champion in the long run. I don't know.
Gary Evans Tallassee, TN
>Interestingly enough, John, what he told me is that the Rikon has a bigger profit margin. It still looks like a pretty good machine to me, although I haven't turned on one yet.
Gary
Just the opposite here...
Peter Teubel
>Lots of the Rikons we've sold have been returned. The Rikon bandsaw is a decent machine but their lathe is....well, this is a family forum, so I'll be nice...not the best. As far as Jet goes, its a regional thing...service all depends on their local rep. Between Jet, Rikon, and Delta, we always push the Jet because of the latter's QC issues.
Ben Aragon
>Trevor,
I tried both lathes at my local Woodcraft store, and I went with the JET 1014VS. My biggest problem with the Rikon lathe is how loud it is. The Jet is very quite has less vibration and after a few hours turning it makes a noticeable difference. The Rikon has many advantages though, I think it�s a good first try for Rikon.
Best Regards,
Ben
