John Lucas:
Allen Neighbors
>John, you advised tek that you ground your hollowing tool nose to look like your bowl gouge. Any chance of posting a photo of it?
I'm just dense, I guess.
AL
John Lucas:
Allen Neighbors
AL
Re: John Lucas:
>Allen I've loaned my camera out so I can't take a photo right now. Hold your index finger out and look at it. That's how I've ground it but it isn't very critical. I have rounded over the corners on my sharpening wheel. To sharpen the cutter I hold it so the front angle is correct (about 65 to 75 degrees but I never measure) I grind the front and then move the tool to the right and tilt it slight to the right and move it around the rounded corner of the stone so the side of the stone grinds the left side of the tool. Then I move to the left side of the stone and slide the tool around the rounded edge and tilt is slightly to the left to grind the right side of the tool. Sometimes I have to go back and round the front edge a little.
When I get my camera back I'll take a couple of photos to show how this works. I sharpen all my small hollowing tools this way as well as my HSS 3/16" cutters.
Re: Thanks, John,
Allen Neighbors
>that explanation did it for me. I've got it. I've been doing some of my Oland Tool cutters that way. No need for the photo now. Unless someone else is more dense than I am. :o)
Thanks John, for taking the trouble.
AL
Re: Thanks, John,
Don Tewell
>I'm still dense, and also fairly new at turning. Please post pic when you can. Thanks.
