Need Design/Form Help
Charlie Anderson
>Here's a norfolk island pine bowl which has been roughed and dried. I began to finish it but wasn't happy with the way it was going.
I'm looking for suggestions.
I was thinking of leaving the dimensions as they are but narrowing the diameter of the bowl between the top and pencil line to have an ogee.
But I was also thinking of lowering the top of the bowl to approximately the pencil line.
What do you think?
Re: Need Design/Form Help
>Charlie, it's looking good. If it was me I would try to main it taper in toward the pencil line starting at the top lip. I think making this a long gentle curve going down toward the pencil line. I make narrower at the pencil line to achieve this and then try to round out the bulge at the bottom to blend the two. The top part should be easy. getting the bulge at the bottom to look right will be tough. Take it slow and look at it often. Take it off the lathe and turn it upside down occasionally and that will help you see the bottom bulge better. This is going to be a really nice piece.
Bill Neddow
>I think John has given you good advice. It should look like a tall, thin brandy snifter when it is done. Classic design.
Re: Need Design/Form Help *LINK*
RussFairfield
>This one was #8 on the Chat Room discussion this past Wednesday night. This is the form Bill is referring to and this one is about the same size as yours.
Wally's bowl
Charlie Anderson
>John
Am I interpreting you correctly? You'd start at the current lip, cut a concave curve to below the pencil the pencil line and then reduce the diameter to something attractive at the knot ring. I need a CAD/CAM program for bowl design.
Looking at Raffin's Bowl Design book, I don't see anything the resembles this except where the diameter of the edge is greater than the diameter at the knot ring.
I know I want to emphasize the knot ring.
