Veritas - Innovation in Tools
sanding spalted maple
Ronnie
>Today I started finish turning a spalted maple bowl and when I got it the way I wanted it I started power sanding with 80 grit to get out some ridges I had left.When I stoped to check my work I realized the spalted portion had sanded away more than the solid wood and left a depresion.
I have never had this problem before.I cut it back down to where it is more or less level and put some Waterlox on the splated part hoping this would make it harder.
Does anyone have any suggestions?
Ronnie
Re: sanding spalted maple
Bill Neddow
>Hardening it with a finish like Waterlox or sanding sealer (Polyall 2000) is great. Then sand using a hard backing pad on your sander. Often I will hang up my drill and sanding disk and just use a piece of wood with the sandpaper wrapped around. I have a small block of wood, about 4 inches long and 1.5 inches wide with a tightening curve on one end (sort of a French curve from old drafting days). Great for getting into the curves.
Bill Neddow
>The reason for using the hard backing pad for the sandpaper is so you will knock off the high (and harder spots) while leaving the softer wood you have already gouged out alone. A soft sanding pad will get down in the hollows and attack the softer wood again.
Ronnie
>Thanks Bill,
Do you think I should use a sanding block through all the grits or just the heavy ones?
Ronnie
