Measuring thickness of HF's
Don in Denver
>Been trying to make some small vase-shaped HF's.(2-2 1/2" dia. x 5-7" height) I seem to go through the wall either when undercutting the rim down to the side or toward the bottom as it tapers down. I've tried using a bent coat hanger that I saw Bob Rosand use on his ornament video, but I can't seem to make one that will go through the 1/2" opening and still be able to give me an accurate reading on the walls etc. How are you all measuring in these situations?
Re: Measuring thickness of HF's
Steve Mushinski
>Don,
If you look on the left click on turning archive and search ' caliper ', you will find a post by Wally Dickerman showing many different measuring methods. Some were home made and some are store bought. There is a ton in information in the archives for those people interesed.
Steve
Brad Vietje
Brad Vietje
>Wally's caliper designs are excellent. The ones made by McNaughton are also very good. I make lots of small and medium hollow forms, and I haven't seen any one caliper that will do it all. For smallish ones I use a lot of bent wire, but I bend 'em out of either heavy copper wire or aluminium wire because it's so easy to bend by hand. You need to experiment with different shapes to be sure you're measuring at a right angle (normal to the surface) to get an accurate measure -- any angled measurements will make you think you have a lot more wood than you do !
If you have a H.F.that's damaged, or you can dedicate one to the cause, try cutting through the side wall on purpose, paying close attention to the change in the sound as it gets thin, thinner, and then too thin. They will also sound different if they are too thin overall, vs just thin in one spot.
Safe Spinning,
Brad Vietje
Newbury, VT
Don in Denver
>Thanks Brad and Steve great info. I'll hopefully get a chance to try it tomorrow. Don
