Hollowing tools for beginner
Lawrence
>I've only been turning for about 6 months but enjoy it thoroughly. I want to try to turn some hollow forms but am confused by the different types of hollowing tools out there. Any recommendations for which tools I should purchase (Ellsworth, Hamlet, Jamieson, Kelton, Sorby, Wodcut, others...)?
Re: Hollowing tools for beginner
Carole Valentine
>Lawrence,
What kind of lathe do you have and what sort of hollow forms do you intend to start with? Knowing this may help folks advise you.
Dawn Adams
>I was also considering to begin hollowing. I have a Powermatic 20" and was considering the Kelton Hollowing Rig since I already have the coring set. However, I have also been looking into the Jamieson Hollowing System. Should I start with a set of small hollowing tools just to practice and then move up to a large system (rig, laser guide, etc) or should I just jump in with both feet and start with the larger system? I think my ultimate goal would be to turn larger hollow forms. Any advice is greatly appreciated.
Thanks in advance
Dawn Adams
Lawrence
>Thanks Carole. Good point. I've got a Jet Mini and would like to try turning some vessels or vases to start.
>Dawn Even with a boring bar system you will still find you need the manual hollowing skills. I think it's best to learn to hollow by hand and then step up to the captured bar systems. I'm fond of the John Jordan style hollowers and use them in my captured bar system as well. They are simple, the cutters are easy to get and to sharpen and they work well. John's video or DVD is also excellent.
I don't have much experience with other brands so I can't compare. I do have a sorby curved bar the i use on occasion. It has a larger cutter and I use it to clean up the inside if I've done a poor job with the 3/16 cutter that come with my Jordan style tool.
I've made most of my hollowing tools. You can buy the 3/16" HSS cutters at your local machine tool supply. They are too long but you can score them with a file and break them to length. (I use a dremel with a cutter to score them) Then simply drill a 1/4" hole in the tip of a 3/4" bar and insert the cutter and glue it in with CA glue. Then make a handle and you in business.
The curved boring bars are a little harder to make so I won't go into those.
Starting point...
T Daniel
>if you hollow you will eventually need several tools because each one has its limits. Start with deep open top vases so you can see your tool work and that helps you develope the technique needed so you can do it blind later when you get into working through a small opening. A good tool to start with is a swan neck hollower. Next would be an armbrace unit such as the Don Pencil tool. After that you would want a captured rig such as the Jamieson. Depending on how deep you want to go there will be several alternatives there. Even with a captured rig you will need the armbrace for some tight corners.
TD
Re: Hollowing tools for beginner *LINK*
georgetroy
>I have most every hollowing tool out there. I find those tools with outriggers to be the safest. I use the captured hollowing tools like the Kelton for big stuff. My favorites at the present time is the Al Basham tools. I have both the 1/2" and 5/8". I have arthritis in my hands and just don't have the strength I use to have. Even on my Sorbys I have the handle so that I can resist the torque. GT
Basham Tools
Paul in Phoenix, AZ
>I to use an Basham style tools. Here is a photo of the tools I use for small (up to 8") vessels. For the mini lathe you will have to have a longer tool rest made.
David Propst
>I also primarily use the Johnston-Basham styles tools for hollowing The 5/8th Basham tool and a straight boring bar would be a great start. The tool is easy to control and with light cuts is a joy to use. Fo vessels 8" in depth/diameter thay are teh best I have used.
Here is a review of them on the Kestrel Creek website and a link to Al Basham's website. Read the review, it says it all. Paul Porter also has a very good webpage with pics. of the tool in use.
That these tools are not more popular is really a mystery to me.
Best Regards,
David
Lawrence
>Thanks everyone. This has been very helpful. :)
Brad Vietje
What He Said...
Brad Vietje
>John wrote what I was thinking of typing, so I'll just add two small points:
1. Find your local turning club, and speak up -- ask who does hollow forms, and get to know them. An experienced H.F. turner one-on-one is your best asset.
2. Check out all the videos you can find. I recommend John Jordan's as well as David Ellsworth's. For books, I learned a lot from Robert Chapman's book "Woodturning: A Fresh Approach" which is an EXCELLENT book, and has a great section on hollow form turning.
Safe Spinning,
Brad Vietje
Newbury, VT
Brad Vietje
OOPS -- one more thing...
Brad Vietje
>Um... I should have added that Hollow Forms really aren't beginner-level projects. Not that a new turner couldn't make very nice hollow forms, but that there's a heck of a lot going on in there, and a lot to learn and master. Many beginners have to work out why they get catches on spindles, or inside bowls, or making beads with a skew. If you make a hollow form with a smallish opening, all these things can happen, but you can't see them...not really all that easy.
I jumped into hollow forms pretty early in my turning learning curve, because H.F.'s are what really drew me into turning at a more serious level. Because I hadn't really understood a few fundamantal concepts, I ended up hurting my right elbow (tendonitis) which got pretty bad. For about 6 months just opening a door or drinking from a glass caused me to wince, and I had no strength. By trying to muscle my way, I had done serious damage to the tendons of my arm, whereas now I can hold the tools lightly, and go for control and finesse, which I couldn't do until I really understood what was happening with the different cutting and scraping tools.
Best of luck, and be careful !
Safe Spinning,
Brad Vietje
Newbury, VT
