Re: Scorpion Carole V.
Don Pencil
Don Pencil
>Carole V.
Good point.
I've always had a larger/longer lathe when attacking anything that would be longer than the stock mini or midi. Actually the bed extention has not been brought up before, or at least as I can remember.
I suppose those that have only the one lathe and the extention could remove it when working on a vessel that requires the Scorpion.
Do you think that is an option?
Also, Garrett brought up a good point in the earlier string.
For the Stinger only. The handle can be turned 30-45 Degres (probably counter clockwise) while still keeping the tool level. You would rotate the tool in the handle that many degrees. Whatever amount is comfortable for the individual turner.
I often do this when using a bowl gouge tool in the Scorpion handle.
What say you?
(Readers be aware that I am the manufacturer of these tools. I look forward to your thoughts on these tools and hope that you find my input helpful to you.)
Don
WWW.DONPENCIL.COM
Re: Re: Scorpion Carole V.
Carole Valentine
>Hi Don,
I am sitting here looking at my Stinger and can't figure out how in the world I would rotate a square tool shaft 35 to 40 degrees in the handle? If the shaft were round, yes. Am I missing something here? Do you make Stingers with round shafts now?
As far as removing the extension bed from my Jet mini, I would sooner toss a tool in the dark recesses of my shop (where things disappear forever!) than go through all that to use it! LOL I don't think that would be a viable option for many people.
Of course neither of these factors really affect me anymore, since I have a larger lathe in addition to the Mini. Also, if I want to use the tools on my Mini, I just stick them in my Hosaluk handle with an adapter.
