A55 Smoothing Plane
Which lathe for beginner?
Bob Fawcett
>I think I would like to try my hand at turning. I have never turned wood. I did some work with a metal lathe years ago, but probably not relevant.
What lathe should I get?
I would probably start turning spindles for legs or bedposts.
Start with something under $1000, then give me the next step up if I upped my budget.
Thanks
Re: Which lathe for beginner?
Jet Mini
Jim Shaver - Oakville, Ontario
>Hi Bob,
I'd look at a Jet Mini. It's such a well made and designed lathe. It's one of two lathes I own. It has the potential to give you the learning and insights into what interests you and help you to decide if you like turning and what you like about it. From there you will have better clariety in what you want in a bigger lathe should you want one down the road. It's also a lathe that is very common and often much sought after in resale.
Like I said I have two lathes, I bet that there are many others here with two lathes and one is a Jet Mini. I doubt that any of them would part with it, I won't.
Chuck and tool Sizes for the Jet match my General 160, so it makes tool purchases simple.
take care,
Jim
Jet Mini with Varible speed
Wayne Cooper in Charlotte
>The difference in the price of the two is very small. I do not know anyone who has regretted getting the Varible speed. As you progress to a larger lathe I think you will keep the VS to do smaller projects.
I am a beginner and I have a Nichols but I use my Jet VS all the time. Good luck Wayne
Re: Jet Mini
>I could not agree with Jim more. I see too many people spend a little more money(than the Jet) on a cheap lathe and then they are frustrated with it. The Jet is such a well built lathe that it outperforms biggers lathes in terms of smooth operation and how everything should work,(not necessarily size). I bought a Delta variable speed lathe and it had a lot of vibration. I didn't realize it was the lathe because I thought it was my skills that were the problem. I sold and purchased a mini lathe (Nova Comet which was the precurser to the Jet mini). I could not believe how much smoother it ran. My turning advanced to the next level immediately. It works so good I still have it as well as several other lathes. The Jet mini is very similar to my Nova. I have turned on at least 2 dozen of these lathes and have taught classes with all Jet mini's. They hold up extremely well and all the problems they have are easily repaired.
You will eventually step up to a bigger lathe but this one is a great starter lathe.
Rick Davenport
>I've been turning for all of 9 months, so I am no expert.
When I decided to get into turning I did a lot of homework and decided I wanted a Nova DVR.
In deference to my wife, I backed off and narrowed it down to the Jet Mini and the Delta Midi.
I ended up with the Delta.
Why? Because it was on sale and the bed extension was thrown in for free (which, by the way, is still in the box).
Since then I have turned on the Jet and of course used my Delta regularly. Once turned on, I can find little difference between the two.
If I had to do it all over again, I would go for the Nova.
Why? Because I am going to get one as soon as monetarily possible. And even if I had found that turning was not for me, I would have had no trouble selling a Nova for near retail.
A wise man told me (after the fact): Establish your minimum lathe needs then go for double what you think you need.
Besides, with all the tools, gizmos, chucks and watchamacallits that you end up buying to further your addiction, the lathe is just a small piece of the pie.
Rick
What about the Grizzlys?
Bob Fawcett
>I have seen good reviews on some of the other Grizzly tools, are the lathes good?
Re: What about the Grizzlys?
Allen Neighbors
>I have a Grizzly 5979 - 12in swing, gap bed. It replaced an old Sears tubular that I never used but once (I bent the shaft with my first turning). The Griz is pretty good, but. There is some things I would change if I could. The tool rest has been replaced twice due to breakage, and it doesn't clamp tight enough due to the way it's engineered. The tail stock base had to be ground down a little to match up with the headstock. It was too low for me, so I raised it 5-1/2 inches with 2X6's laminated with plywood. If I had been smart, I would have replaced the old Sears with either a OneWay or a Nova. My next one will be one of those, unless I can spring for a VB36. :o)
JMHO
AL
Re: Also,
Allen Neighbors
>... the speed can't be slowed below 250 or so, and sometimes when making a heavy cut, I bog down the 1 HP motor.
AL
Richard Allen
Richard Allen
>Hi Bob
A Oneway 1640 would be a good starter lathe. The $3000+ price appears high when you first look at it. But the resale value of that lathe VERY GOOD. So for about the same loss risk as a 1442 Jet you can be turning on one the best lathes made.
Barry Turner
>A Jet mini lathe is a great place to start. Many people like the VS model, but I think it's a waste of money on a mini lathe. I get by perfectly well on my belt-drive mini. It's solid, quiet, well-built and smooth. Just pick a mid-range speed and you can turn most anything within the capacity of a mini lathe without fussing over speed. It has 1" X 8 threads and # 2 Morse tapers, both standard features on larger lathes, so accessories you buy now may well fit your next lathe. Don't buy mini tools. Buy standard-sized tools. Then you can use them on your next lathe as well. Mini tools are harder to control and sharpen. Be prepared to also spend some money on sharpening......a good 1750 rpm grinder with a Oneway jig. You have to learn to sharpen well, before you can learn to turn well.
Re: I agree. I bought mine AFTER I bought a 24"
Al Crandall (NE of Indy)
>I also like the Jet mini. I use a Jet 1642 but this summer I added a mini - it's a good second lathe for me and quite portable. It would be an excellent starter lathe, as would be the Delta or Rikon.
Just don't do what I did at first - needing to make a quick turning and not knowing any better, I ran down to HD and bought the Ridgid 1/2 hp tube lathe (identical to the old Craftsman). While it certainly did the trick (and got me hooked on turning), the quality and utility was low. No comparison to a Jet (or Delta or Rikon) I ended up giving the tube lathe to a friend.
Lou Krupnick
>Consider the new Craftsman: < $500, 1 HP, 14" swing, has pretty reasonable low speed (400rpm) torque & comes with a decent banjo & tailstock. I compared it to the 12" Jet /Griz /& Delta's of the same size & think it really is much better constructed. Been using mine for a little more than a year now w/ no problems & I've had some really large chunks of wood on it w/o any problems.
The only thing I don't like is the optional stand which is a little flimsy, although some additional weight will go a long way. At the end of the day it will leave you with an extra $500 to spend on good steel, a grinder system, and a perhaps a bandsaw which you're going to want in pretty quick order. A grand goes by in a NY minute in this sport.
Lou in MD
Re: Jet Mini *LINK*
matt fallon
>i apologize for dragging up a month-old post,
i already own a Large old-iron powermatic model-45, but want a mini for bringing to my club and for craft fairs etc.
i was just reading all teh reviews and comments on the Jet mini verse delts,rikon,jetVS... i guess i came to what i already felt was right, im getting a jet-1014 mini.
just wanted to mention for anyone else on the fence.
amazon.com has a presidents sale this weekend, $50 off $250 for all tools, and jet has a $25-rebate also. making the jet mini $205 free shipping. i think this is the best price/deal going at this time? im placing my order tomorrow
amazon tools sale.
Re: Jet Mini
>Wow I guess I'll hang on to the 2 that I've been rebuilding. I sure won't be able to make any money on them.
