Scorpion Question
Scorpion Question
Scorpion Question
Harvey Bernstein (Philly)
>Is a Delta Midi lathe underpowered for a Scorpion set?
If so, what would be the best minimum Hp to use with the Scorpion.
TIA
Harvey
Re: Scorpion Question
Jorge Castaneda
>Hi Doc, long time no see.
It will be ok if you use only the Stinger set, I have the same lathe and I use the Stinger on it with good results.
I use the Scorpion on my Nova 3000, 1 1/2HP.
Jorge
Carole Valentine
>Jorge,
One problem I seemed to have with using the Pistol Grip handle on my Jet mini is clearing the lathe bed with the handle. I always had to have the tool rest a tad higher than I wanted. Do you have this problem on the Delta?
Jorge Castaneda
>Hi Carol,
Yes I have the same problem and that limits the forms you can create, in the minis, the deepest I ever done is 7", the Nova with the swinging head is more versatile and has the guts, you know that, you have that too. I prefer to have the tool completely horizontal
Pistol Grip
Garrett in Victoria
>Can you turn the main so that the grip is on top and use it that way?
Don Pencil
Notes from the manufacturer
Don Pencil
>Hello to all,
I hope I can put a little light on this.
The Scorpion should work very well on the Jet, Delta, and other 10" lathes. You can bog the lathe down with very agressive use the same as you can with a bowl gouge.
The handle clearance on these lathes would not come into play with the Scorpion as the Scorpion bars are longer than the lathe bed.
The Stinger is shorter and the handle does come into play there. The handle is over the bed and must be elevated slightly along with the tool rest. Although this does not leave the turner with a level tool, it should not matter. The tools have a small cutting surface and are not prone to catches the way the larger tools are.
Cerritos Community College in Norwalk, CA has 24 Jet mini lathes on which they teach several beginning and advanced classes. They use the Scorpion and Stinger sets to teach the hollow vessel part of the advanced class. Some of the members of the class are from the local Liesure World and do very well with these tools on these lathes.
The Scorpion does work better on a larger lathe if you dig in with the straight tool. The curved tool should not be used to hog out the wood and therefore will not bog down the smaller lathes.
I hope this was helpful. I am looking forward to more comments on these tools. I often learn good information about them on this sight from the users and that is used for future improvements.
Thanks to all and Be Well,
Don
WWWW.DONPENCIL.COM
>Hi Jorge, it has been a long time. Hope all is well with you and yours. I still haven't been able to get in that Down East vacation I've wanted. I'am going to Deerfield though.............in Florida in 2 weeks. No lobster, but warmth!!
Thanks for your reply,
Harvey
Thanks everyone
Re: Notes from the manufacturer
Carole Valentine
>"The handle clearance on these lathes would not come into play with the Scorpion as the Scorpion bars are longer than the lathe bed."
Unless you have a bed extension. ;) But on the size pieces that I was turning on the Jet Mini, I nearly always used the Stinger anyway. I love that tool for smaller pieces because I can maintain a small opening. Anything that I use the Scorpion on is usually mounted on my Nova.
