Shop Arrangement
Shop Arrangement
Shop Arrangement
Don Oetjen
>Can someone refer me to a site that has suggestions on how to set up a turning shop? One of the newer turners in our club wants to get started on the right foot and I would like to refer her to a more professional source than what I can offer. Thanks
Re: Shop Arrangement
Re: What's wrong with right here?
RussFairfield
>The lathe is the focal point. It occupies the space where the table saw would be in another shop. Set the lathe in the middle of the room so you can have access around it on all sides. Everything else is secondary; put it where it fits.
If this is a new shop, they will never regret putting a small lavatory with a big sink and hot water in the shop.
JKJ in East TN
>I like the bandsaw, sharpening station, sandpaper and such, and the lathe tools (of course) very near the lathe, all within arms reach or without taking more than a few steps. A u-shaped layout works well. In my last shop and current temporary shop I had/have the lathe nearly up against a wall and shelves. I reach over the lathe for sandpaper roll dispensers, guages, calipers, etc, to the right for lathe tools, chucks and misc, and turn around to the bandsaw and sharpining table. At one time I had things arranged where I had to walk further for sharpening and bandsawing, and I found it less efficient. What I miss at the moment is a window - I plan a high window over the lathe for my new shop.
Light
Jorge Castaneda
>Also, position the lathe where it will get the most daylight, and install several lights for night use, to me light is extremely important
Jorgw
heat pump
Ed Moore
>When we moved to SW Virginia in 2002 I had a budget for the shop. We did several things that have pleased me, but the best was the installation of a good heat pump and some additional insulation. Hot or cold outside, my shop is comfortable inside.
Russ commented about a good sink and a lavatory. I second the wisdom of his suggestion. It is not a viable option in my case, but I wish it was. The short walk up the hill to the shop frequently triggers a need to turn around and go back to the house. ;^D
Ed
Re: Light
Gary in Zirconia, NC
>I'd be carefull where the window lines up with the "line of fire" of the lathe. I like my tools right behind me as I stand at the lathe.
Dan in the NW
>You might check out your local public library. Ours has a pretty good section on woodworking. Here are links to the two books I read while contemplating the layout of my garage/shop.
Setting up Shop http://www.taunton.com/store/pages/070492_tcpg.asp
How to Design and Build Your Ideal Workshop http://www.best-airtools-store.info/howtodes.html
There is also a link in the left side menu to 'Shop Tours' http://www.shoptours.org/
Good Luck
Dan
The main thing is:
T Daniel
>keep the lathe away from a wall. When things come off the lathe without proper authorization there is a 50% chance the piece will go away from you but if close to a wall the piece hits the wall and comes back at you. Give the runaway bowl a place to go. Other than that just place the bandsaw against a wall (wheels under the saw are nice), the grinder near or on the lathe, a good sturdy worktable, a hanging floating dust filter, and a dust collector preferably behind a sound absorbing wall, and a small air compressor next to the dust collector. This would be a nice start.
